AndyArbs Posted October 18, 2010 Share Posted October 18, 2010 Hi guys, I'm not sure if this has been asked before but i couldn't find anything on it. Ive used CAD before in high school using prodesktop and am now using autocad. In pro desktop I could convert a 3D model into 2D engineering drawings. Just wondering is it possible to do the same thing in AutoCAD I have the 2010 version of it. Any help would be much appreciated thanks. Andrew Quote Link to comment Share on other sites More sharing options...
viviancarvalho Posted October 18, 2010 Share Posted October 18, 2010 Welcome to the forum AndyArbs The answer to your question is very simple. Just get the view you want of your 3d model on the screen & use the "FLATTEN" command, then select the desired objects. This will flatten all selected 3d objects on to one plane. Be sure to keep a copy of your original 3d model. Regards Vivian. Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 18, 2010 Share Posted October 18, 2010 Could that be "Flatshot" you were referring to Vivian? There are other methods too. They include SolProf, and the combination commands SolView/SolDraw. Quote Link to comment Share on other sites More sharing options...
viviancarvalho Posted October 18, 2010 Share Posted October 18, 2010 Could that be "Flatshot" you were referring to Vivian? There are other methods too. They include SolProf, and the combination commands SolView/SolDraw. No Remark it is "Flatten" & works well with me, atleast in 2010 My command line pasted below Command: Command: _qsave Command: flatten Initializing... Select objects to convert to 2d... Select objects: *Cancel* Quote Link to comment Share on other sites More sharing options...
JD Mather Posted October 18, 2010 Share Posted October 18, 2010 I would not use flatten. I would use flatshot or solview, soldraw. But coming from Pro/Desktop you are going to struggle with AutoCAD. You would be better off taking your model into Autodesk Inventor. Students can get Inventor for free from http://engineersrule.org Quote Link to comment Share on other sites More sharing options...
nestly Posted October 18, 2010 Share Posted October 18, 2010 FLATTEN is quick and easy, however FLATSHOT is a better solution if the 3D geometry is more complex. http://screencast.com/t/n2tYtK7oPW1 Quote Link to comment Share on other sites More sharing options...
