donbosco
Dimensions
donbosco
Hi
This may sound silly but I got one drawing on which I can't put dimensions. there is something that has changed and i cant figure it out wht.
Note-I have put diff dimensions on same drawing before without problem.
Currently i choose command it ask to select origin of first line then second then placement but as soon as i place it, it does not do anything and starts asking origin of first line and all that all over again.
Some tips much appreciated.
thanks lot.
Share this post
Link to post
MarcoW
Hi DonBosco,
I would really like to investigate your drawing but unfortunately you didn't post it.
Maybe you can still do it? I hardly come across drawings that are "mysterious" so I like a good struggle.
Regards,
MarcoW.
Share this post
Link to post
JPlanera
without seeing the drawing, i can only assume that you are trying to place dimensions on a layer that is frozen/off.... check the current layer and make sure it is active?
Share this post
Link to post
nestly
Is your current layer turned off. If so, you may find a lot of duplicate dimensions when you turn it back on.
Share this post
Link to post
JPlanera
Dont you hate it when you post at the same time as someone else??? :roll:
Share this post
Link to post
nestly
Only when their reply is above mine :lol:
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
