hi,all
the following codes are used to draw dynamic text and lines.
as the picture describe.
but error always happened. after I debug.
I found the codes exited in these codes.
(setq text (vla-addtext mSpace fh (vlax-3d-point nextPt)))
the whole program.thank you for your time to read this.
(defun c:tt(/)
 	(vl-load-com)
(defun *error* (msg)
	(setvar "osmod" osmode_old)
(defun text_length (Text / textent ang sinrot cosrot t1 t2 p0 p1 p2 p3 p4)
	(setq 	textent (entget (vlax-vla-object->ename Text)))
	(setq 	p0  (cdr (assoc 10 textent))
			ang  (cdr (assoc 50 textent))
			sinrot (sin ang)
			cosrot (cos ang)
			t1  (car (textbox textent))
			t2  (cadr (textbox textent))
			p1  (list (+ (car p0) (- (* (car t1) cosrot) (* (cadr t1) sinrot)))
				(+ (cadr p0)
				(+ (* (car t1) sinrot) (* (cadr t1) cosrot))
			p2  (list
				(+ (car p0)
				(- (* (car t2) cosrot) (* (cadr t1) sinrot))
				(+ (cadr p0)
				(+ (* (car t2) sinrot) (* (cadr t1) cosrot))
			(distance p1 p2)
(setq mSpace (vla-get-ModelSpace(vla-get-ActiveDocument (vlax-get-acad-object))))
 	(setq entbak (ssadd))
 	(setq osmode_old (getvar "osmode"))
 	(setvar "osmode" 0)
 	(setq pt (getpoint "\nget the center point."))
 	(command "_.circle" pt)
  	(princ (strcat "\ninput the radius of circle"))
 	(command pause)
 	(setq cir (vlax-ename->vla-object (entlast)))
 	(ssadd (entlast) entbak)
 	;start to input the makr.
 	(setq hasMore T)
 	(while hasMore
  	(setq nextPt (grread T 4 0)
  		   readtype (car nextPt)
	  	   readvale (cadr nextPt)
    (cond ((= readtype 5)
				(setq nextPt (cadr nextPt))
				(setq nextPt (trans nextPt 1 0))
				(setq basePt (vlax-curve-getclosestpointto cir nextPt))
				(if (not line)
						(if (not fh)
							(setq fh "A")
						(setq txtlen (text_length text))
						(setq l2end (vla-addline mSpace (vlax-3d-point nextPt) (vlax-3d-point l2end)))
						(vla-put-startpoint line (vlax-3d-point basePt))
						(vla-put-endpoint line (vlax-3d-point nextPt))
						(vla-update line)
						(setq ptt (car nextPt))
						(if (> ptt pt)
								(setq textleft (+ (car nextPt) (getvar "dimgap")))
								(setq l2left (+ (car nextPt) txtlen (getvar "dimgap")))
								(setq textleft (- (car nextPt) (getvar "dimgap") txtlen))
								(setq l2left textleft)
						(vla-put-insertionpoint text (vlax-3d-point list textleft (+ (cadr nextPt) (getvar "dimgap")) 0))
						(vla-update text)
						(vla-put-startpoint l2 (vlax-3d-point nextPt))
						(setq l2end (list l2left (cadr nextPt) 0))
						(vla-put-endpoint l2 (vlax-3d-point l2end))
						(vla-update l2)
		   ((= readtype 3)
				(setq i nil)
		   ((or (= 25 readtype) (= 13 readtype))
find the reason.should be :
(setq text (vla-addtext mSpace fh (vlax-3d-point nextPt) (getvar "dimtxt")))
the updated codes:
(defun c:tt(/ line fh text)
 	(vl-load-com)
			sinrot (sin ang)
			cosrot (cos ang)
				(+ (cadr p0)
			p2  (list
				(+ (car p0)
				(+ (cadr p0)
			(distance p1 p2)
 	(setvar "osmode" 0)
 	(command pause)
 	(setq hasMore T)
 	(while hasMore
				(if (not line)
						(if (not fh)
							(setq fh "A")
						;(setq txtlen (text_length text))
						(setq line (vla-addline mSpace (vlax-3d-point basePt) (vlax-3d-point nextPt)))
						(setq l2end (list (+ (car nextPt) txtlen) (cadr nextPt) 0))
						(setq l2 (vla-addline mspace (vlax-3d-point nextPt) (vlax-3d-point l2end)))
						(vla-update line)
						(setq ptx (car pt))
						(if (> ptt ptx)
						(vla-put-insertionpoint text (vlax-3d-point (list textleft (+ (cadr nextPt) (getvar "dimgap")) 0)))
						(vla-update text)
						(vla-update l2)
		   ((= readtype 3)
				(setq hasMore nil)
