BlackBox Posted November 17, 2010 Posted November 17, 2010 Perhaps you should mention what needs to be modified? No, no... let's all guess. Perhaps the OP is just having a little trouble learning to code... thanks man is perfect but as i Sade it needs sum modifywill you help me again ?? Alex, here's where I would start --> at the command line type VLIDE, then hit Enter. Within the VLIDE, open Fixo's .LSP file. Now hit F1 to read the Developer Documentation. Hope this helps! Quote
alex198617 Posted November 18, 2010 Author Posted November 18, 2010 ones again thank you "FIXO" Georgia,tbilisi,varketili.dwg Quote
fixo Posted November 18, 2010 Posted November 18, 2010 ones again thank you "FIXO" Hi Alex, I could not open the drawing, because of it was made in A2010 version or higher I currently use just A2008 Can you resave it in A2008 version and send it again? Translated message: Алекс, я не смог открыть твой рисунок, потому что он был создан в версии А2010 или выше В настоящее время я использую Только версию А2008 Можешь сохранить чертеж в формате 2008 и выслать его снова? Олег Quote
alex198617 Posted November 18, 2010 Author Posted November 18, 2010 i think you can made it can we talk in English or you prefer Russian ? мы можем говорить на английском или вы предпочитаете Русски? ჩვენ შეგვიძლია ვილაპარაკოთ ინგლისურად თუ რუსული გირჩევნია? in case if you know Georgiana Georgia,tbilisi,varketili.DWG Quote
fixo Posted November 18, 2010 Posted November 18, 2010 i think you can made it can we talk in English or you prefer Russian ? in case if you know Georgiana we can talk English only Ok, I'll try to do it tomorrow See you Quote
fixo Posted November 19, 2010 Posted November 19, 2010 try edited lisp instead change whatever you need by yourself coz I have not have a time for that (vl-load-com) (defun load_ltype (ltname / fname);FH (if (not (tblsearch "ltype" ltname)) (and (if (zerop (getvar "measureinit")) (setq fname "acad.lin") (setq fname "acadiso.lin") ) (vl-cmdf "._-linetype" "_L" ltname (findfile fname) "") ) ) (princ) ) (defun c:demo (/ *error* cnt curcol curlr curlts elist en osm pt ptblocks pts ) (defun *error* (msg) ;; Application error handler byby Doug Broad ; create standard error handler (cond ((not msg)) ; normal exit, no error ((member msg '("Function cancelled" "quit / exit abort")) ( ) ) ; escape ((princ (strcat "\nError: " msg)) ; display fatal error )) (setvar "cmdecho" 1) ; restore environments (if osm (setvar "osmode" osm)) (if curlr (setvar "clayer" curlr)) (if curcol (setvar "cecolor" curcol)) (if curlts (setvar "celweight" curlts)) (command "._layerp" ) (command "._undo" "_end") (princ) ) (setvar "cmdecho" 0) ; turn echo off (command "._Undo" "_end") ; close any open group (command "._undo" "_begin") (load_ltype "KANALIZACIA") (command "_.-layer" "_Th" "*" "") (setq osm (getvar "osmode")) (setq curlr (getvar "clayer")) (setq curcol (getvar "cecolor")) (setq curlts (getvar "celweight")) (setvar "cmdecho" 0) (setvar "clayer" "0") (setvar "cecolor" "1") (command "_celtype" "KANALIZACIA") (setvar "celweight" 53) (setvar "celtscale" 15.0) (setq pts nil) (if (setq pt (getpoint "\nPick first Point: ")) (progn (setq pts (cons pt pts)) (command "_.pline" "_non" pt "_W" "0.0" "0.0") (while (setq pt (getpoint "\nPick next point: " pt)) (setq pts (cons pt pts)) (command "_non" pt)) (command ""))) (command "_celtype" "continuous") (setvar "cecolor" "256") (setq ptblocks (reverse (cdr (reverse (cdr pts))))) (foreach p ptblocks (command "_.-insert" "block-1" p "1.0" "1.0" "0.0")) (setq pts (reverse pts) cnt 1) (setvar "celtscale" 1.0) (setvar "cecolor" "7") ( while (cadr pts) (command "dimaligned" (car pts) (cadr pts) (polar (cadr pts) (* pi 0.5)1.0)) (setq en (entlast)) (setq elist (entget en)) (setq elist (entmod (subst (cons 1 (strcat "{\\C8;\\FESRI Geology AGSO 1;{\\H7.0;" (itoa cnt) "}}\\P{\\C7;\\FAcadNusx;{\\H3.0;<>}}"))(assoc 1 elist)elist))) (entmod (subst (cons 41 1.25)(assoc 41 elist)elist)) (entupd en) (setq pts(cdr pts) cnt (1+ cnt))) (*error* nil) (princ) ) (prompt"\nType DEMO to execute") (prin1) Quote
alex198617 Posted November 19, 2010 Author Posted November 19, 2010 This is great fixo thank you with your help i save 3X more time with this code Quote
