Ok, I have been to many sites and read all I could about this issue. Anytime that my rig tries to do a regen, AutoCad slips into this never ending not responding phase. Sometime it will only last a minute or two and other times it will last so long that it makes me end the process which in turn makes me loose any unsaved work. I have found one culprit that if it is unchecked in the (Options / Display tab) (Draw true silhouettes for solids and surfaces).
If I uncheck that box everthing will work fine but for some unknown reason this box will somehow be checked again and the problem will resurface.
PS I am also running CadPipe on top of AutoCad.
Thanks
