I do not know how to write code in any shape, form or fashion and I have a request to those who know how to do such things.
I am using R2007 and my request is for a stamp that would be automatically put on every drawing that is opened.
What I would like is REFERENCE DRAWING in Romans.shx placed on the drawing approximately 2" vertically and approximately 1/2" horizonally from 0,0.
The text size to be approximately 1/4" high for an A size sheet but changing as the paper size increases. (A, B, C, D, E)
Is this possible?
Either way, I thank you very much for your help.
Bill Williams
Why not make what you want as a DWG and insert it on the drawing - or put it into your template file?
That is a good way to do it but we have borders provided by corporate and the powers-to-be here want a text line that will automatically insert. They want to keep corporaate happy.
Inserting the text is easy, but changing the size (since you don't have access to annotative objects) is more of a challenge.
Consider the following:
Does the object need to be in model or paper?
What change is made to alter the size (eg. dimscale variable, viewport scale)?
What's the titleblock name?
Are they all different names or is it a dynamic block?
It would work better if it is in paper space and as to the text size it would be better if it was large enough on a e size sheet to read easily.
The title block/border is supplied by corporate, as I mentioned earlier, with attributes for drawing description, etc.
Make a notepad file acaddoc.lsp
(defun S::STARTUP()
(setq title_block "corporatetitleblock")
(setq ent (cdr (assoc 2 (tblnext "block" T))))
(while (/= ent nil)
(if (= ent title_block)(command "insert" "C:\\myfile\\mydrg.dwg" "0,0" "1" "1" "0"))
(setq ent (cdr (assoc 2 (tblnext "block"))))
This will search all the blocks in the drawing and if it finds the corporate title block inserts your drawing at 0,0
Hope this helps
I just wanted the words REFERENCE DRAWING to insert every time a drawing was opened at the location prescribed earlier
Quickly hacked together, put this in your ACADDOC.lsp Bill:
(defun c:RefDWG ( / str pos hgt ) (vl-load-com)
 (setq str  "REFERENCE DRAWING" ;; Text String
       pos '(0.5 2.0 0.0)       ;; Text Position
       hgt  0.25                ;; Text Height
 (vla-AddText
   (vla-get-PaperSpace
     (vla-get-ActiveDocument
       (vlax-get-acad-object)
   str (vlax-3D-point pos) hgt
(c:RefDWG)
Or more robust to account for current locked layer:
 (if
   (vl-catch-all-error-p
     (vl-catch-all-apply 'vla-AddText
       (list
         (vla-get-PaperSpace
   (princ (strcat "\n** Error Creating Text: " str " **"))
(c:RefDWG)
Thank you Lee.
I will try it first thing after the Thanksgiving holiday
(defun foo (/ ss)
 (foreach layout (layoutlist)
   (or (setq ss (ssget "_X" (list '(8 . "REFERENCE-TEXT") '(0 . "MTEXT") (cons 410 layout))))
       (entmakex (list '(0 . "MTEXT")
                       '(100 . "AcDbEntity")
                       '(100 . "AcDbMText")
                       '(10 0.5 2.0 0.0)
                       '(1 . "REFERENCE TEXT")
                       '(40 . 0.25)
                       (cons 410 layout)
Bill,
Is this for one computer or multiple computers?
Do you want it to be automatic when any drawing is opened or do you want to type a command to run it?
Is this only for a particular client or for any drawing opened?
Lee, I couldn't wait. Had to try it before I left for the day. I can't seem to get it to work.
Attached is my acaddoc.lsp and I attached the RefDWG at the bottom.
Where did I go wrong?
;;Automated acaddoc creation 7:57 AM 8/23/2010 theswamp.org
;;Write all files in a directory (and possibly subdirectories) to load in the ACADDOC.lsp
;;If the ACADDOC.lsp is not found, it will be created in the SavePath as shown at the top of the code.
;;Although, for large numbers of files, I would suggest looking into the AutoLoad function to save memory.
(defun c:acaddoc ( / SavePath f l )
(vl-load-com)
;; © Lee Mac 2010
(setq SavePath
(cond
( (setq tmp (getvar 'ROAMABLEROOTPREFIX))
(or (eq "\\" (substr tmp (strlen tmp)))
(setq tmp (strcat tmp "\\")))
(strcat tmp "Support\\")
( (setq tmp (findfile "ACAD.pat"))
(setq tmp (vl-filename-directory tmp))
tmp
(t
(popup "Warning" 16 "DCL Save Path not Valid")
(exit)
(or (setq f (findfile "ACADDOC.lsp"))
(setq f (strcat SavePath "ACADDOC.lsp"))
(if (and (setq l (LM:GetAllFiles nil T "*.lsp"))
(setq f (open f "a")))
(foreach x l
(write-line
(strcat "(load "
(vl-prin1-to-string x) " \"Failed to Load: " (vl-filename-base x) "\")"
f
(close f)
(princ (strcat "\nWritten " (itoa (length l)) " Files to Load in ACADDOC.lsp"))
(princ "\n*Cancel*")
;;--------------------=={ Get All Files }==-------------------;;
;; Retrieves all files or those of a specified filetype that ;;
;; reside in a directory (and subdirectories) ;;
;; Author: Lee McDonnell, 2010 ;;
;; Copyright © 2010 by Lee McDonnell, All Rights Reserved. ;;
;; Contact: Lee Mac @ TheSwamp.org, CADTutor.net ;;
;; Arguments: ;;
;; Dir - [str] (optional) Directory, if nil function will ;;
;; prompt for directory selection ;;
;; subs - [boole] if T, subdirectories are included ;;
;; filetype - [str] (optional) Filter for filetype ;;
;; Returns: VLA Variant Object of type specified ;;
(defun LM:GetAllFiles ( Dir Subs Filetype / GetSubFolders Shell Fold Dir )
(vl-load-com)
;; © Lee Mac 2010
(defun GetSubFolders ( folder / _f )
(mapcar
(function
(lambda ( f ) (setq _f (strcat folder "\\" f))
(cons _f (apply (function append)
(GetSubFolders _f)))
(cddr (vl-directory-files folder nil -1))
(cond
( (not
(or
(and Dir (vl-file-directory-p Dir))
(setq Shell (vla-getInterfaceObject
(setq ac (vlax-get-acad-object)) "Shell.Application")
Fold (vlax-invoke-method Shell 'BrowseForFolder
(vla-get-HWND ac) "Select Directory" 512))
(vlax-release-object Shell)
(if Fold
(setq Dir (vlax-get-property
(vlax-get-property Fold 'Self) 'Path))
(vlax-release-object Fold)
(and (= "\\" (substr Dir (strlen Dir)))
(setq Dir (substr Dir 1 (1- (strlen Dir)))))
Dir
nil
( (apply (function append)
(vl-remove (quote nil)
(mapcar
(function
(lambda ( Filepath )
(mapcar
(function
(lambda ( Filename )
(strcat Filepath "\\" Filename)
(vl-directory-files Filepath Filetype 1)
(append (list Dir)
(if subs (GetSubFolders Dir))
(vla-AddText
(vla-get-PaperSpace
(c:RefDWG)
You are missing a paren for this line: (defun c:RefDWG
Did you try my submission?
Thanks Alan for spotting that paren. I haven't had a chance to try yours. Does your load the same way, with acaddoc?
Alan, I don't understand
Just follow everything with (foo).
They're getting ready to lock the doors so I have to go!
Talk to you again Monday and again THANKS!
