lorim Posted December 1, 2010 Posted December 1, 2010 I keep getting the following error everytime AutoCAD opens. FATAL ERROR: Unhandled e0434f4dh Exception at 751b9617h A week ago I moved some files around including the file that had my personal settings (plot styles, text styles, etc.) I have worked in it everyday but just realized they were missing today so I closed autocad, moved the file back to where it was....then opened autocad again. This is when I started getting the fatal error. The disks are in another city so I would like to try to avoid re-installing. Any ideas? Quote
harycad Posted December 3, 2010 Posted December 3, 2010 I look like the CAD software have problem. The best way is re-install your CAD. Otherwise you may set autosave 5 or 10 min. to minimize the lose of your work. Quote
nukecad Posted December 3, 2010 Posted December 3, 2010 Could be a Microsoft .NET Framework error, take a look at this on the Autodesk site- http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13109351&linkID=9240657 Quote
