Quick switching between areas in model, ACAD 2008
sbzatto
Hi,
I learned a quick switch combination some time ago, and used it to great extent whilst creating drawings for my university projects. It's been some time since I had to work with AutoCAD however, and I've forgotten what exactly it was.
What it did was the following: Let's say I have 3 plans in 1 model. I would zoom in as I liked on plan 1, and save this viewpoint as 1, zoom in on the 2nd plan, save it as viewpoint 2, zoom in on the 3rd plan, and save it as 3. Now by using the same combination but with a different first function (I can't recall what were these functions) AutoCAD automatically zoomed in on the viewpoint specified by either 1,2 or 3.
I'm pretty good with the keyboard and prefer to use it instead of navigating my way with the mouse, that's why I found this method to be convenient. Has anyone used this method and remembers the combination of functions to pull it off? If so I would be thankful if you could share it. I tried to google search it, that's how I found it in the first place, but I couldn't find it anymore, unfortunately.
Hope somebody can help!
Link to post
I have LISPs set up V1, V2, etc. sets my views, and RV1, RV2, etc. recalls them it is very simple.. Give this a try.
(DEFUN C:V2 ()
 (COMMAND "VIEW" "W" "2" PAUSE PAUSE)
 (PRINC)(PRINC "View 2 set!")(princ))
(DEFUN C:RV2 ()
 (COMMAND "VIEW" "R" "2")
 (PRINC)(PRINC "View 2 Restored!"))
Link to post
^^^ JPlanera beat me to it, see above for the lisp solution
The command is VIEW. If you use -VIEW you will get the command line, then you type S for save, type a number or letter. Now when you want to move to another named view you use -VIEW enter R enter 1 enter. If you set up some custom buttons or set a simple lisp command then you can simply pick the button to move to View 2, etc. or type V2 to move to view 2.
Link to post
I think it was something a bit different. One had to Save the views (ex. - V1, V2, V3, etc.) then one would Restore a view. That's where the "R" came in.
I'm guessing no matter what drawing you are working on you would consistently use the same default names when saving views right? Ex. - View1, View2, View3, etc.
Link to post
Found this.....
F1 displays help
F2 displays text window
F3 switches object snaps
F4 toggles table mode
F5 toggles isometric planes
F6 toggles DUCS (switches coordinate display, till A2006)
F7 toggles grid display
F8 toggles ortho mode
F9 toggles snap
F10 toggles polar tracing
F11 toggles object tracing
F12 toggles dynamic input (2006+)
ESC cancel changes, cancel grips
TAB cycles osnaps
SHIFT (on object selection) removes objects
DEL erases objects (hold when pointing)
Ctrl+0 toggles clean-screen mode (2004+)
Ctrl+1 displays Properties window
Ctrl+2 displays DesignCenter window
Ctrl+3 displays Tool palette (2004+)
Ctrl+4 displays Sheet Set Manager, or Content Manager (2005+, ADT2004)
Ctrl+5 displays Info Palette, or Project Navigator (2005-2007, ADT2004)
Ctrl+6 displays dBConnect window
Ctrl+7 displays Markup Manager (2005)
Ctrl+8 displays Quick Calculator (2006+)
Ctrl+9 shows/hides Command line (2006+)
Ctrl+A selects all thawed objects (2002)
Ctrl+Shift+A toggles group selection (group/single)
Ctrl+B toggles snap
Ctrl+C copies content to Clipboard
Ctrl+Shift+C copies with reference point
Ctrl+D toggles coordinates display (dynamic UCS, till 2009)
Ctrl+E switches isoplanes
Ctrl+F toggles osnaps
Ctrl+G toggles grid display
Ctrl+H toggles Pickstyle (group and hatch selection)
Ctrl+Shift+H toggles Palettes display (2009+)
Ctrl+I toggles coordinate display (2009+)
Ctrl+J repeats the last command (Enter)
Ctrl+K displays the Hyperlink dialog
Ctrl+L toggles Ortho mode
Ctrl+N starts new drawing
Ctrl+O opens a drawing
Ctrl+P print a drawing
Ctrl+Shift+P toggles Quick Properties display (2009+)
Ctrl+Q quits AutoCAD (2004+)
Ctrl+R switches to the next viewport
Ctrl+S saves drawing
Ctrl+Shift+S saves drawing as (2004+)
Ctrl+T toggles the Tablet mode
Ctrl+U switches polar tracing
Ctrl+V pastes the Clipboard contents
Ctrl+Shift+V pastes contents as block
Ctrl+W toggles object tracing
Ctrl+X cuts contents to the Clipboard
Ctrl+Y redoes the undone action
Ctrl+Z undoes the last action
Ctrl+PgDn switches to the next layout (2004+)
Ctrl+PgUp switches to the previous layout (2004+)
Alt+F8 VBA macros
Alt+F11 VBA editor
temporary override keys (2006+):
Shift switches ortho mode
Shift+- switches dynamic UCS mode (2007+)
Shift+) switches object tracing mode (2007+)
Shift+. switches polar mode
Shift+A switches osnaps
Shift+E switches endpoint osnap
Shift+C switches center osnap
Shift+D disables osnaps and tracing
Shift+M switches middle osnap
Shift+Q switches object tracing osnap
Shift+S enables osnap override
Shift+W starts SteeringWheel (A2009+)
Shift+X switches polar tracing
CTRL+mouse cycles selection of overlapping objects (till 2006)
Shift+space cycles selection of overlapping objects in 2D (2007+)
CTRL+space cycles selection of overlapping sub-objects in 3D (2007+)
CTRL+ALT extrudes the selected region into 3D - PRESSPULL (2007+)
CTRL+arrow moves cursor
Arrow up/down - command history
CTRL+SHIFT+letter goes to the property in the Properties window
ALT+down arrow opens a list in the Properties window
ALT+up arrow closes a list in the Properties window
Link to post
It's either use a lisp routine or a series of macros (depends on how many views you typically work with). The only way I can think of doing this at the keyboard is to set up some new keyboard shortcuts in the CUI.
Link to post
The -VIEW is it. I used to do -v,s,1, enter, and then -v,r,1 enter. I guess that's where the 'r' came in. Thanks alot! :)
Yea thats cool... If you like to hit 'enter' a bunch of times... :P
Link to post
Sounds like a macro in the making.
How about using the Macro Recorder? 2008 has that feature doesn't it? Create a macro then play it back.
Link to post
