oliverpockets
Viewport Masking?
oliverpockets
Is there a way to prevent a viewport from showing behind an object drawn in paper space? It's not attached to the side of the title block so I can't _vpclip around it. It's floating in the lower left corner, and I don't want the contour lines on this map to show up behind it.
Share this post
Link to post
rkent
I guess I don't understand why vpclip won't work. You can also draw any shape and make that a viewport. Mview, object, select. Same as vpclip just another way of getting there. I tend to avoid anything but rectangular viewports so I will copy one viewport on top of another, pick one, pick the grip and stretch over, pick the other viewport and stretch up, as an example.
Share this post
Link to post
oliverpockets
I guess I could have done a better job explaining. As far as I know, vpclip just alters the boundaries of the viewport you pick. I need to almost cut a hole out of the viewport.
Share this post
Link to post
rkent
viewports inside viewports - 3 methods
1) First draw a rectangle that will be the size wanted for the big
viewport. Use the Region command and make that a region, now use the
Mview command, Object option and pick the region. Adjust the view in
that viewport accordingly.
Now draw circles or polygons, etc. that will represent the smaller
viewport(s). Place those where you will want them. Use the Region
command again. Use the subtract command and pick the large region
then the smaller one(s). Now draw the circles again in the blank
space, use the Mview command, Object option. Adjust those viewports
accordingly. Because these are regions now you won't be able to edit
them like a normal viewport, IE: grip stretch, etc.
2) In MS use wipeout to hide the area you want another VP to reside.
Now in PS use MVIEW and grab the opposite corners of the wipeout.
3) In PS you can draw a continuous pline with a large rectangle and
then move into the center and draw a smaller rectangle, all in the same
pline command. You will have two plines one of top of the other going
to the smaller rectangle but that is ok because it won't show. Now use
the MVIEW command and use Object option. Now use MVIEW again to define
the smaller viewport grabbing the opposite corners of the small rectangle.
Share this post
Link to post
oliverpockets
Those are all very helpful and #3 solved my issue. Thank you very much, rkent.
Share this post
Link to post
rkent
You are welcome. #3 is the easiest to make adjustments to, #1 give the flexibility to have circles, ellipses, etc. without too much work. I never have liked wipeouts so I don't use #2 personally.
Share this post
Link to post
danellis
What is the paperspace object? If it's text or Mtext you can give it s background colour of white.
Alternatively try putting a wipeout above the viewport and below the ps object.
dJE
Share this post
Link to post
