How do I set the Z plane to 0 as standard?
CADKitten
I'm drawing a 2D model but for some annoying reason each new line (or pline) that I draw is created as 3D, so when I filter a corner for example it says that the lines are non co-planar, which is easy to fix but annoying because it shouldn't be like that in the first place! :unsure:
Help much appreciated, thanks!
