Extract XYZ values from multiple blocks
justindm
  • Replies 39
  • Tharwat
    12
  • alanjt
    6
  • Lee Mac
    5
  • symoin
    5
Posted Images
Make sure the VLIDE isn't inserting tabs into your code:
Tools » Environment Options » Visual LISP Formatting Options » (uncheck) Insert Tabs
Thanks Lee .
That's right , it was checked. so I released it .
What is the problem that may cause for the others when they copy and paste codes in their Vlide editors ? Would codes get far from eachothers ?
I am still wonder why !
Thanks
@Tharwat - yours works awesome! much simpler than the eattext (and much less filling :lol:)
Is there a way to specify the location of the output file? Or just to the same place as the dwg location?
You're welcome .
Here is one according to your request.
(defun c:THex (/ dir fNme ss)
 ; THARWAT 2010
(if (and  (setq dir (getvar 'dwgprefix))
          (setq fNme (open (strcat dir "Block-coordinates.txt" ) "w"))
          (setq ss (ssget "_:L" '((0 . "INSERT"))))
    (lambda (i / ss1 e pt1 )
      (while
   (setq ss1
          (ssname ss (setq i (1+ i))))
     (setq e
        (entget ss1))
           (setq pt1
          (cdr (assoc 10 e)))
   (write-line
     (strcat  (rtos (car pt1) 2)
             "," (rtos (cadr pt1) 2)
                 ","  (rtos (caddr pt1) 2))
     fNme)
     -1
   (close fNme)
 (princ "\n Written by Tharwat")
Enjoy. :)
Tharwat
  • 6 years later...
You're welcome .
 ; THARWAT 2010
      (while
   (setq ss1
     (setq e
        (entget ss1))
           (setq pt1
          (cdr (assoc 10 e)))
   (write-line
     fNme)
     -1
   (close fNme)
Enjoy. :)
Tharwat
Thanks for this beautiful code....
Could you please modify to include the layer of the block (layer on which it is inserted)
Thank you.
Can you show how it should look like in the txt file to allow me to modify the codes with one shot if possible?
Please find the attached it has Pointid or Sl. No, Easting, Northing, Elevation and Code.
Some can like this even without the Sl.No. will be great.
Thanks.
(defun c:Test (/ sel dir fil int ent get pnt)
 ;; Tharwat - Date: 03.Aug.2017	;;
 (if (and (setq sel (ssget "_:L" '((0 . "INSERT"))))
          (setq int -1
          (setq fil (open (strcat dir "Block-coordinates.txt") "w"))
   (while (setq ent (ssname sel (setq int (1+ int))))
        (setq get (entget ent)
              pnt (cdr (assoc 10 get))
     (write-line (strcat (rtos (car pnt) 2) "," (rtos (cadr pnt) 2) "," (rtos (caddr pnt) 2) "," (cdr (assoc 8 get))) fil)
 (if fil (close fil))
          (setq int -1
Firstly I apologize for the delay and Then thanks for this code.
This works exactly as required but only one issue is its creating the list in reverse order. (newer first and older last). Can it be reversed to older first and newest last.
Thanks
Thanks
Its okay - you're welcome anytime.
Are you after sorting the list as per the smallest X coordinates?
not exactly,
now your code creates the list with the order of block created or inserted from newer to older into the drawing, required exactly the same with from older to newer..
Thanks
not exactly,
Thanks
          (setq int (sslength sel)
   (while (setq ent (ssname sel (setq int (1- int))))
  • 5 months later...
