I'm using AutoCAD 2009. When I edit text the ribbon changes to display the text formatting ribbon, great, but when I've finished editing it doesn't revert to the standard ribbon or the ribbon I was in before the text edit. Is this a quirk?
You are correct. After editing your MText the Ribbon should revert to the last Tab (and its respective panels) that you were using.
If yours doesn't then it would appear there is something amiss.
Do you have all updates installed for AutoCAD 2009?
