harrison-matt Posted December 30, 2010 Posted December 30, 2010 (edited) Anyone know how to draw a multileader using visual lisp and dxf? Kind Regards, Matt Edited December 30, 2010 by harrison-matt Quote
mkweaver Posted December 30, 2010 Posted December 30, 2010 (defun c:test1 () (setq aspace (if (= 1 (vla-get-activespace (setq doc (vla-get-activedocument (vlax-get-acad-object))) ) ) (vla-get-modelspace doc) (vla-get-paperspace doc) ) ) (while (setq p0 (getpoint)) (vlax-invoke aspace 'addmleader (append p0 (polar p0 (/ pi 4) 3)) 0 ) ) ) Quote
harrison-matt Posted December 30, 2010 Author Posted December 30, 2010 It works great, my only question is: If my current leader style contains a user defined block, where can i specify the program to include the block when drawing the mleader? Matt Quote
pBe Posted December 31, 2010 Posted December 31, 2010 It works great, my only question is: If my current leader style contains a user defined block, where can i specify the program to include the block when drawing the mleader? Matt If your current Mleader style does have a user defined block, thene verytime you use this it shows the block Now, this is an overide (defun c:test1 () (setq aspace (if (= 1 (vla-get-activespace (setq doc (vla-get-activedocument (vlax-get-acad-object))) ) ) (vla-get-modelspace doc) (vla-get-paperspace doc) ) ) (while (setq p0 (getpoint)) [color=blue](vla-put-arrowheadblock[/color] (vlax-invoke aspace 'addmleader (append p0 (polar p0 (/ pi 12) 9)) 0 ) [color=blue] "YourBlockName")[/color] ) ) you can use variable for the block name, but you need to know the block name beforehand or add a prompt for the block name Quote
