I'm doing a fillet between 2 circles, and it only will give me an inside arc, one that goes under, when I need it to be an outside arc. Thank you.
Go the other way. In other words if you are starting your arc on the left hand circle and finishing on the right hand, reverse that. Start the arc on the right side and pull toward the left. You should see it go up instead of down.
Thanks, I wasn't thinking. Instead of fillet command, I needed to do a start, end, radius arc. Doing the fillet no matter which side I clicked on first always gave me the same thing.
Fillet will do that. If you click above the centerline of the two circles, it throws the arc down. if you click below it, it goes up.
You may be looking for C ttr Circle tangent tangent radius it works properly for a third circle/arc between two existing arcs/circles, you have to trim for an arc it no more S bends.
