Jack_O'neill Posted January 11, 2011 Share Posted January 11, 2011 (edited) Greetings all, I am new to this forum and am quite impressed by the knowledge of the members. I came across the topic of 3D tubes and I have a question/problem that I think fits here…. I wish to automate the creation of tubes, on the order of thousands, from a file of 3D polyline x-y-z coordinates. I have the x-y-z coordinates of thousands of 3D polylines in Excel and text file. Each 3D polyline consists of only 3 points, like a triangle in 3D space with one side missing. For each 3D polyline, I wish to convert it into a solid tube of fixed diameter. Currently to create the tubes, I am manually drawing a circle at the base of each polyline, and also manually extruding the circle to follow the path of the 3D polyline. One possible advantage is that the diameter of all tubes is the same. If necessary, I can program in BASIC to create some brute force script (.scr) files. I would like to avoid LISP, for now. Attached is an much scaled down example of the final output, consisting of 5 pipes, starting with 5 polylines. Any thoughts, comments or suggestions would be greatly appreciated. Back in the old Mechanical Desktop days, I could have helped you out with this. You could drive drawings from an excel spreadsheet back then in that product. However, that was 10 years ago, and I drifted over into architectural drawing and worked for companies who had their own ways of doing things, and I'm afraid I've lost touch with some of the newer features in autocad. I see in the help files that you can use parametric constraints in 2010, so if you could figure out how to access them from ms excel or access you could do these drawings from your spreadsheet. I am not the one to help you set it up though. I've forgotten just about everything about how to do that, and it probably doesn't work the same way now anyway. Edited January 11, 2011 by Jack_O'neill can't type tonight to save my life Quote Link to comment Share on other sites More sharing options...
rob8lyn Posted January 11, 2011 Share Posted January 11, 2011 Back in the old Mechanical Desktop days' date=' I could have helped you out with this. You could drive drawings from an excel spreadsheet back then in that product. However, that was 10 years ago, and I drifted over into architectural drawing and worked for companies who had their own ways of doing things, and I'm afraid I've lost touch with some of the newer features in autocad. I see in the help files that you can use parametric constraints in 2010, so if you could figure out how to access them from ms excel or access you could do these drawings from your spreadsheet. I am not the one to help you set it up though. I've forgotten just about everything about how to do that, and it probably doesn't work the same way now anyway.[/quote']Thanks for your reply, Jack. Actually, I don't need to drive the drawing from Excel, it just happens that my data starts there. Probably should not have mentioned it in the OP, as it isn't critical to the process. In fact, I used a script (.scr) file to draw the 3D polylines. I think what I'm looking for is the correct script commands that would do something like this: (1) draw each 3D polyline, (2) a circle and then (3) automatically extrude the circle to that particular polyline. As I mentioned, I can create a huge script file from the polyline data using BASIC, so I think I would only need to know script commands for one 3D polyline + circle + extrude along polyline path sequence. I hope that makes sense to somebody out there. Quote Link to comment Share on other sites More sharing options...
SEANT Posted January 11, 2011 Share Posted January 11, 2011 I see you’re using AutoCAD 2006, so VBA is still an option. I had this routine hanging around, see if it will work for you. It creates and positions a circle, then extrudes along all the selected paths. The 3dPolys would already have to be in place, however. See this link on how to run a vba program: http://www.cadtutor.net/forum/showthread.php?30608-FAQ-How-do-I-run-a-VBA-routine Option Explicit Private Sub MakeExtrusions() Dim intCode(0) As Integer Dim varData(0) As Variant Dim objProfile As AcadCircle Dim ent3PLine As Acad3DPolyline Dim objProfReg As AcadRegion Dim objRod As Acad3DSolid Dim dblDia As Double Dim deltaX As Double, deltaY As Double, deltaZ As Double Dim dblStartPoint() As Double Dim dblNextPoint() As Double Dim varEndPoint As Variant Dim varCen As Variant Dim arrOrigin(2) As Double Dim curves(0 To 0) As AcadEntity Dim varRegion As Variant Dim dblVector() As Double varCen = arrOrigin On Error GoTo Abort dblDia = ThisDrawing.Utility.GetReal("Input a rod Diameter, <enter>, then select polylines:") Set objProfile = ThisDrawing.ModelSpace.AddCircle(varCen, dblDia / 2) objProfile.Visible = False intCode(0) = 0: varData(0) = "POLYLINE" If SoSSS(intCode, varData) > 0 Then For Each ent3PLine In ThisDrawing.SelectionSets.Item("TempSSet") dblStartPoint = ent3PLine.Coordinate(0) dblNextPoint = ent3PLine.Coordinate(1) dblVector = NormalizeST(VectorFrom2PtsST(dblStartPoint, dblNextPoint)) objProfile.Center = dblStartPoint objProfile.Normal = dblVector Set curves(0) = objProfile varRegion = ThisDrawing.ModelSpace.AddRegion(curves) Set objProfReg = varRegion(0) Set objRod = ThisDrawing.ModelSpace.AddExtrudedSolidAlongPath(objProfReg, ent3PLine) objProfReg.Delete Next End If objProfile.Delete Exit Sub Abort: End Sub Function VectorFrom2PtsST(dbl1stPt() As Double, dbl2ndPt() As Double) As Double() Dim dblDummy(0 To 2) As Double dblDummy(0) = dbl2ndPt(0) - dbl1stPt(0) dblDummy(1) = dbl2ndPt(1) - dbl1stPt(1) dblDummy(2) = dbl2ndPt(2) - dbl1stPt(2) VectorFrom2PtsST = dblDummy End Function Function NormalizeST(dblVect() As Double) As Double() Dim dblMag As Double If Not IsVectorZero(dblVect, 6) Then dblMag = (dblVect(0) ^ 2 + dblVect(1) ^ 2 + dblVect(2) ^ 2) ^ 0.5 dblVect(0) = dblVect(0) / dblMag dblVect(1) = dblVect(1) / dblMag dblVect(2) = dblVect(2) / dblMag End If NormalizeST = dblVect End Function Function IsVectorZero(dblVector() As Double, Optional lngPrecision As Long = 6) As Boolean IsVectorZero = False If Round(dblVector(2), lngPrecision) <> 0# Then Exit Function If Round(dblVector(1), lngPrecision) <> 0# Then Exit Function If Round(dblVector(0), lngPrecision) <> 0# Then Exit Function IsVectorZero = True End Function Sub SSClear() Dim SSS As AcadSelectionSets On Error Resume Next Set SSS = ThisDrawing.SelectionSets If SSS.count > 0 Then SSS.Item("TempSSet").Delete SSS.Item("RemoveSSet").Delete SSS.Item("EntireSS").Delete End If End Sub Function SoSSS(Optional grpCode As Variant, Optional dataVal As Variant) As Integer Dim TempObjSS As AcadSelectionSet SSClear Set TempObjSS = ThisDrawing.SelectionSets.Add("TempSSet") 'pick selection set If IsMissing(grpCode) Then TempObjSS.SelectOnScreen Else TempObjSS.SelectOnScreen grpCode, dataVal End If SoSSS = TempObjSS.count End Function Quote Link to comment Share on other sites More sharing options...
rob8lyn Posted January 11, 2011 Share Posted January 11, 2011 (edited) I see you’re using AutoCAD 2006, so VBA is still an option. I had this routine hanging around, see if it will work for you. It creates and positions a circle, then extrudes along all the selected paths. The 3dPolys would already have to be in place, however.See this link on how to run a vba program: http://www.cadtutor.net/forum/showthread.php?30608-FAQ-How-do-I-run-a-VBA-routine Option Explicit Private Sub MakeExtrusions() Dim intCode(0) As Integer Dim varData(0) As Variant Dim objProfile As AcadCircle Dim ent3PLine As Acad3DPolyline Dim objProfReg As AcadRegion Dim objRod As Acad3DSolid Dim dblDia As Double Dim deltaX As Double, deltaY As Double, deltaZ As Double Dim dblStartPoint() As Double Dim dblNextPoint() As Double Dim varEndPoint As Variant Dim varCen As Variant Dim arrOrigin(2) As Double Dim curves(0 To 0) As AcadEntity Dim varRegion As Variant Dim dblVector() As Double varCen = arrOrigin On Error GoTo Abort dblDia = ThisDrawing.Utility.GetReal("Input a rod Diameter, <enter>, then select polylines:") Set objProfile = ThisDrawing.ModelSpace.AddCircle(varCen, dblDia / 2) objProfile.Visible = False intCode(0) = 0: varData(0) = "POLYLINE" If SoSSS(intCode, varData) > 0 Then For Each ent3PLine In ThisDrawing.SelectionSets.Item("TempSSet") dblStartPoint = ent3PLine.Coordinate(0) dblNextPoint = ent3PLine.Coordinate(1) dblVector = NormalizeST(VectorFrom2PtsST(dblStartPoint, dblNextPoint)) objProfile.Center = dblStartPoint objProfile.Normal = dblVector Set curves(0) = objProfile varRegion = ThisDrawing.ModelSpace.AddRegion(curves) Set objProfReg = varRegion(0) Set objRod = ThisDrawing.ModelSpace.AddExtrudedSolidAlongPath(objProfReg, ent3PLine) objProfReg.Delete Next End If objProfile.Delete Exit Sub Abort: End Sub Function VectorFrom2PtsST(dbl1stPt() As Double, dbl2ndPt() As Double) As Double() Dim dblDummy(0 To 2) As Double dblDummy(0) = dbl2ndPt(0) - dbl1stPt(0) dblDummy(1) = dbl2ndPt(1) - dbl1stPt(1) dblDummy(2) = dbl2ndPt(2) - dbl1stPt(2) VectorFrom2PtsST = dblDummy End Function Function NormalizeST(dblVect() As Double) As Double() Dim dblMag As Double If Not IsVectorZero(dblVect, 6) Then dblMag = (dblVect(0) ^ 2 + dblVect(1) ^ 2 + dblVect(2) ^ 2) ^ 0.5 dblVect(0) = dblVect(0) / dblMag dblVect(1) = dblVect(1) / dblMag dblVect(2) = dblVect(2) / dblMag End If NormalizeST = dblVect End Function Function IsVectorZero(dblVector() As Double, Optional lngPrecision As Long = 6) As Boolean IsVectorZero = False If Round(dblVector(2), lngPrecision) <> 0# Then Exit Function If Round(dblVector(1), lngPrecision) <> 0# Then Exit Function If Round(dblVector(0), lngPrecision) <> 0# Then Exit Function IsVectorZero = True End Function Sub SSClear() Dim SSS As AcadSelectionSets On Error Resume Next Set SSS = ThisDrawing.SelectionSets If SSS.count > 0 Then SSS.Item("TempSSet").Delete SSS.Item("RemoveSSet").Delete SSS.Item("EntireSS").Delete End If End Sub Function SoSSS(Optional grpCode As Variant, Optional dataVal As Variant) As Integer Dim TempObjSS As AcadSelectionSet SSClear Set TempObjSS = ThisDrawing.SelectionSets.Add("TempSSet") 'pick selection set If IsMissing(grpCode) Then TempObjSS.SelectOnScreen Else TempObjSS.SelectOnScreen grpCode, dataVal End If SoSSS = TempObjSS.count End Function Sweet! Thanks, Sean!! Yes, the 3D polylines are in place, so this has a chance of working. I will need some time to get up to speed on VBA since I normally use an external BASIC compiler (JBASIC) to manipulate data and text files. I will most definitely give it a try and report back. BTW - Is it possible to use this routine starting with 3D splines instead of 3D polylines? If so, how would I go about modifying it? ====== EDIT: Just did a quick and dirty test and IT WORKS!!! It also treats the 3D spline and polyline as the same type, which is great. Sean: you are awesome. Edited January 11, 2011 by rob8lyn Quote Link to comment Share on other sites More sharing options...
