muck Posted September 24, 2008 Posted September 24, 2008 I have done some AutoCAD 2008 drawings. These drawings need to be converted to Microstation dgn format. When that is done we get text that if offset from orginal points. Text characters with extra spaces inbetween them, etc. How can I make a clean conversion to Microstation format? I have AutoCAD 2009 available. thank you Quote
chulse Posted September 24, 2008 Posted September 24, 2008 What process did you use for the conversion? How'd ya do it? Quote
muck Posted September 24, 2008 Author Posted September 24, 2008 I batched converted the drawing thru V8 microstation. What is the best method to use? Quote
rustysilo Posted September 24, 2008 Posted September 24, 2008 In my experience this is merely an issue of text styles and fonts that are used. You should be able to just switch the fonts of the text to another comparable font in Ms. Quote
muck Posted September 24, 2008 Author Posted September 24, 2008 What text style and fonts should be used? We changed the text style to standard but we still had problems. Quote
rustysilo Posted September 24, 2008 Posted September 24, 2008 That I'm not sure about. When I had the issue I was going from Ms to Acad. I would export from Ms where an arial font was used in the Ms text and after exporting in Acad it was all whacked so I just changed to font in the text style to arial and that fixed it. Quote
muck Posted September 25, 2008 Author Posted September 25, 2008 I am using AutoCAD 2008. I heard that 2009 has a dgn export feature. Will exporting with 2009 cure this text conversion problem? What is the font is best to use in AutoCAD for microstation conversions? Maybe that is the question I should be asking in a new post? Thank you, Quote
rustysilo Posted September 25, 2008 Posted September 25, 2008 You may be better off looking for this answer at the Bentley discussion groups. Please let us know what you find out. Quote
muck Posted September 25, 2008 Author Posted September 25, 2008 Actually the problem with converting to Version 7 of Microstation. It seems like the text widths are off and we have to be manually correct text strings. I will look at the other Bently discussion groups. Quote
