ACAD block with world coordinates
AUW
Hi all,
I'm new to the site. I'm setting out attribute block on a plan and would like to extract the world coordinates of the insertion of the block in to a cad table in the same drawing.
Please help,
thanks AW
There is probably a LISP routine that does that easily for you but I can't use LISP as I'm on LT but I do it long hand by
Creating your table with columns for X & Y
in the first column enter = to start a formula
ctrl f to bring up fields
select object from the first column
click the icon over the second column
select the point from the drawing
select position from the second column
set up the format eg. decimal
deselect the relevent x,y,z coords from the third column
OK
then [/1000] to change to milimetres
[enter]
and that should work!
You can put all of the coordinates in the table if you don't untick any of the x,y or z options but then I'm not sure about the dividing by 1000 or applying any other scaling factors you may need.
Hope that helps.
Many many thanks for your tip, it took me very close to where I wanted to get. However I don't seem to be able to get what I'm after: a table with 3 columns, the first with the tag name, second with 'x' coordinate, third with 'y' coordinate. Following your instructions I only get both coordinates in the same column... any idea what I'm doing wrong, how to achieve the table with 3 columns I described above? If you could point me in the right direction I would much appreciate it!!
Many thanks in advance!!!
OK
[enter]
Hope that helps.
In the cell for the X coordinate bring up field pop up box (ctrl +F) under the third column of the box untick the y and z and that should only leave the x coordinate visible in the cell, then repeat for the y column (you may be able to drag or copy the 'x' cell) and untick the x selection box and tick the y selection box. At lunch if you're still having problems I'll do some screen shots unless someone else can explain it better :)
Hope this helps.
