Hi,
I am searching LISP for Selecting text "A" value and Text "B" value and click on "C" text, then Text "C" automatically should be update as (A-B) as this formula.
for Ex. Text A is "17.010" and Text B is "14.668" if you Select text "A" and Select text "B" and the Select "C" value is automatically updated as "2.342"
It means (A-B)= C (17.010-14.668)= 2.342
Value should be re requere up to 3 desimals.
Is this possible
Thanks
This may help you with it .:)
If you mess clicking on a text it will return from the beginning ( read the command line while invoking the routine)
(defun c:sub (/ ss1 ss2 ss3 st1 st2 st3 e)
; Tharwat 20.01.2011
(while
  (not (and (setq ss1
           (car (entsel "\n Select first text to subtract from :")))
                (setq ss2
           (car (entsel "\n Select second text :")))
                (setq ss3
           (car (entsel "\n Select text to insert the result:")))
       (setq st1
          (cdr (assoc 1 (entget ss1))))
       (setq st2
          (cdr (assoc 1 (entget ss2))))
       (setq st3
          (cdr (assoc 1 (setq e (entget ss3)))))
         (entupd (cdr
           (assoc -1
                  (entmod (subst
                    (cons 1 (rtos (- (distof st1) (distof st2)) 2 3))
                    (assoc 1 e)
                    e)
Edited by Tharwat
codes updated
One comment, the OP requested for a double with 3 decimals as a result, so you may want to use DISTOF instead of ATOI in your code; this function will allow you also to validate the content of the string. The same for ITOA vs. RTOS. Thank you.
Regards,
Mircea
That's right Mircea .
Thank you , Codes updated . :)
Regards,
Tharwat
