Burtzlaff Posted September 24, 2008 Posted September 24, 2008 I'm using AutoCAD Civil 3d 2007 and am currently running into a problem when i textmask an mtext. It immediately sets my 'wipeout' frames setting to off even if it was previously on. It is quite annoying to go back and turn back on the frames after every mask. Is there a system variable or quick answer to keep the frames of my textmask on? Quote
Burtzlaff Posted September 24, 2008 Author Posted September 24, 2008 Is your IMAGEFRAME set to "1"? yes and tframes is toggled on. Quote
BOB'27T Posted September 24, 2008 Posted September 24, 2008 If you can't get that resolved, what about trying MASK? It's a civil function used for hiding parts of surfaces. Quote
alanjt Posted September 25, 2008 Posted September 25, 2008 textmask is just a lisp routine express tool. if you open the file (i'm pretty sure it's still it's own lsp file in 08; have to check when i get to work tomorrow) and change/remove that line of text type: "start" "textmask.lsp" you'll find something like this, just change/remove it: (if (= MTYPE "Wipeout") (command "_.wipeout" "_frame" "_off") ; Turn off wipeout frames ) Quote
GE13579 Posted September 25, 2008 Posted September 25, 2008 You can also just go through the drawing as you would and at the end you can toggle the frames on or off through the WIPEOUT > FRAMES command. Quote
Burtzlaff Posted September 25, 2008 Author Posted September 25, 2008 textmask is just a lisp routine express tool. if you open the file (i'm pretty sure it's still it's own lsp file in 08; have to check when i get to work tomorrow) and change/remove that line of texttype: "start" "textmask.lsp" you'll find something like this, just change/remove it: (if (= MTYPE "Wipeout") (command "_.wipeout" "_frame" "_off") ; Turn off wipeout frames ) perfect answer... thank you so much. Quote
hazardman Posted September 25, 2008 Posted September 25, 2008 i made a coule iof tool bar buttons (macro i suppose) so ic an turn them on or off when required... Quote
