blackeagle1245
arranging scales and drawing vertical duct
blackeagle1245
hello again its good to have forum back again:) so let me make the opening :)
I want to draw a pipe or duct that goes from first floor to roof for example. But I work with constructs which are floor by floor. So is there a way to see this duct or pipe in every construct ?
My second question is how do we arrange scale of mvparts? From where? I can arrange annotation scale but I couldnt find scaling mv parts. :unsure:
Share this post
Link to post
tzframpton
MvParts should always be 1:1 scale. What are you trying to accomplish by rescaling an MvPart?
Share this post
Link to post
blackeagle1245
For example in fire protection systems fire sprinklers seems too small it cant be seem if I print it like that.
Share this post
Link to post
blackeagle1245
Is there a way to work with several constructs at the same time ? Like in the view window?
Share this post
Link to post
tzframpton
I'm not an expert at Constructs. I've used them before but not in detail and I had a difficult time setting them up in the time allotted so never bothered with them again and just haven't had time to teach myself how to use them efficiently yet.
What you can do is edit the Top View block of the MvPart to your liking. This will allow the scale to be viewable in Plan View.
Share this post
Link to post
tzframpton
You know, now that I think about it, you can create a riser as it's own Construct. This way you can assign this construct to every level. Or maybe try it as an Element instead. This is how I would approach it.
Share this post
Link to post
