Modification of Dimension, Text, MText, Leader, ect..
Hi y'all,
I would like to modify or replace all the original command like Text, MText, Hatch, all Dimension, Leaders, etc... is it possible to modify them so that when i type, for exemple "MT" on the command prompt, its automaticaly go on the good layers?
Thanks!
Link to post
Hi Benjo,
By good layers do you mean that once you create an entity it is placed on a specific layer regardless of the layer you are current on? for example current layer "test", run text command, text entity appears on "text layer"
If this is the case a reactor would be a nifty approach.
SOliver
Link to post
Hi SOliver
Exemple:
You have 2 layer on a draw, 0 and A-ANNO-TEXT. Your current layer is 0.
What i would like to find is how to make Mtext automaticaly on A-ANNO-TEXT when i type the Mtext command on command prompt.
I have made a macro button for all this but i prefer type in the command line
Benjo
Link to post
Not sure if I understand the question properly but I believe something like this is what you are looking for
(vlr-command-reactor nil '((:vlr-commandEnded . test)))
(defun test(re arg  /)
 (cond ((eq (car arg) "MTEXT")
  (setq ent(vlax-ename->vla-object(entlast)))
  (vla-put-layer ent "test")
       ;Additional conditions for different functions
Hope this helps,
SOliver
Edited by SOliver
Link to post
