adamsnez Posted February 17, 2011 Posted February 17, 2011 Trying to make a field that auto-updates to whatever the TAB NAME it's on. (confusing wording? sorry!) example: A paperspace tab name of "ABC" (those little folder tabs you name your paperspace layouts on....) I want to make a text-field that updates to the name of the tab it's on. (text field is on tab ABC) then the second tab you make named DEF would have the text-fields auto-update to say "DEF"... This will eliminate me having to manually enter page numbers on the border layout, etc. THANKS IN ADVANCE CT !!! Quote
rkent Posted February 18, 2011 Posted February 18, 2011 Trying to make a field that auto-updates to whatever the TAB NAME it's on. (confusing wording? sorry!) example: A paperspace tab name of "ABC" (those little folder tabs you name your paperspace layouts on....) I want to make a text-field that updates to the name of the tab it's on. (text field is on tab ABC) then the second tab you make named DEF would have the text-fields auto-update to say "DEF"... This will eliminate me having to manually enter page numbers on the border layout, etc. THANKS IN ADVANCE CT !!! Field, System Variable, CTAB Quote
adamsnez Posted February 18, 2011 Author Posted February 18, 2011 thanks. in addition to this thread for ref. if people search the same thing i found this..... If you want to copy a text or block into multiple layouts in your drawing, you may want to use an automatic text which will display the name of the respective layout (paperspace). You can use the Field functionality for this - just insert a field and use the "Other" category, and the "System variable" CTAB value. Or just copy the following line (field code) as a DText: %% The same text will then read e.g. "Layout1" in the first (default named) layout, "Layout2" in the second, etc. This applies both for modelspace and paperspace text entities. Quote
Jesper Hedlund Posted 21 hours ago Posted 21 hours ago The problem is that CTAB is always set to current tab value, which is no pronblem when cycling the different layouts and plotting them. The problem is when using external software where all layouts will display the CTAB name. For a drawing saved in TILEMODE 1: Drawing Tab Attribute value Drawing1.dwg Model Model Drawing1.dwg Layout1 Model Drawing1.dwg Layout2 Model This is what you want to see: Drawing Tab Attribute value Drawing1.dwg Model Model Drawing1.dwg Layout1 Layout1 Drawing1.dwg Layout2 Layout2 Quote
SLW210 Posted 51 minutes ago Posted 51 minutes ago 20 hours ago, Jesper Hedlund said: The problem is that CTAB is always set to current tab value, which is no pronblem when cycling the different layouts and plotting them. The problem is when using external software where all layouts will display the CTAB name. For a drawing saved in TILEMODE 1: Drawing Tab Attribute value Drawing1.dwg Model Model Drawing1.dwg Layout1 Model Drawing1.dwg Layout2 Model This is what you want to see: Drawing Tab Attribute value Drawing1.dwg Model Model Drawing1.dwg Layout1 Layout1 Drawing1.dwg Layout2 Layout2 What external software are you using? You will most likely need a custom solution. Quote
