I want to be able to get the two points between the portion of polyline I select.
example:
the blue line is the portion of the polyline selected and the X's are the two points I wish to get.
I'm able to get this by comparing angles and sorting by distance but there must be a better way.
you just want to select the line and have its endpoints returned as coordinates?
(defun AT:Segment (objPnt)
 ;; Retreive segment number and Start & End points
 ;; objPnt - List with object & point
 ;; Alan J. Thompson, 11.10.09 / 08.19.10
 (if (vl-consp objPnt)
   ((lambda (seg)
      (list seg
            (list (vlax-curve-getPointAtParam (car objPnt) seg)
                  (cond ((vlax-curve-getPointAtParam (car objPnt) (1+ seg)))
                        ((vlax-curve-getPointAtParam (car objPnt) (1- seg)))
     (fix (vlax-curve-getParamAtPoint
            (car objPnt)
            (vlax-curve-getClosestPointTo (car objPnt) (trans (cadr objPnt) 1 0))
eg.
(AT:Segment (entsel))
I was looking at the Curve measurement functions in Developer's Help but could not figure out how to get the end points.
Thank you!! :D
Thank you for that snippet Alanjt, the code i wrote for the same purpose is waaaaayyyyy to long. (DXF codes)
 (vlax-curve-getClosestPointTo (car objPnt) (trans (cadr objPnt) 1 0));<------
Nice :)
Nice :)
Enjoy. I'd like to see you DXF example, if you don't mind sharing. It's always neat to see how others approach a task.
sure, its not pefect though, wrote it for regular shape polylines(squares.rectangles.triangles,closed polygons) because i use distance to test, as much as possible i pick at the middle of the segment :lol:
(defun c:Seg (/ pl ss a_10 pt_lst dst_tst seg_pts)
(if (setq pl (entsel "\nSelect Pline:"))
          (setq ss (entget (car pl)))
 (while (setq a_10 (assoc 10 ss))
          (setq ss (member a_10 ss))
          (setq
            pt_lst
             (cons (cdr (assoc 10 ss)) pt_lst)
            ss (cdr ss)) ;_ end of setq
 (setq dst_tst (mapcar (function (lambda (j) (distance (cadr pl) j))) pt_lst)
   2pt (vl-sort dst_tst '<)
  seg_pts
                 (list
   (nth (vl-position (nth 0 2pt) dst_tst) pt_lst)
   (nth (vl-position (nth 1 2pt) dst_tst) pt_lst))
Your code is more elegant and effective
Oh well :) (lesson learned)
Yeah, I could see where you'd have problems with vertices being close together. I still like it.
yup, bummer huh
I could've made it shorter it i did this way(not that it matters)
       pt_lst (mapcar
                'cdr
                (vl-remove-if-not '(lambda (x) (= (car x) 10)) ss)))
but still.. anyhoo. i'll worked on it when i get time, thank you for the encouragement Alanjt
This may be of interest:
(defun AT:GetVertices (e / p l)
 ;; Return point at each vertex of curve
 ;; e - curve to evaluate (Arc, Line, *Polyline, Spline)
 ;; Alan J. Thompson, 09.30.10
 (if e
   (if (eq (setq p (vlax-curve-getEndParam e)) (fix p))
     (repeat (setq p (1+ (fix p)))
       (setq l (cons (vlax-curve-getPointAtParam e (setq p (1- p))) l))
     (list (vlax-curve-getStartPoint e) (vlax-curve-getEndPoint e))
