place a car on a sloping surface
darris07
im designing a home and im trying to place a vehicle on a sloping parking pad. when i insert a car, it hovers on one end as if the surface was flat. any tricks to fixing this?
When placing the vehicle in your model check the 'Placement' area on your ribbon and play with the options. It should let you place it on the slope plane of the parking pad. Not sure if this is the correct answer as I'm just learning revit myself.
  • 9 years later...
