Seth385 Posted March 24, 2011 Posted March 24, 2011 Hello, I am new here, so excuse me if this question is too direct. I am surveyor and I have measured profile of sea bottom near beach by boat. To be precise I have measured it with Stratabox. I have picture in jpg format and turned it into block into Civil 3d. So i have to scale it and i don't know how. On y axis i have scale to compare scaling with, and on x axis i have coordinates to calculate real distance and then scale it. Only thing i don't know is command and process of scaling. Scaling woul be different on x and y axis. I would appreciate if someone could help me with this issue. thank you. http://img846.imageshack.us/i/spojeniprofil5.jpg/ Quote
KJB Posted March 25, 2011 Posted March 25, 2011 My IT department blocked me from viewing your JPG but I believe I understand what you are asking. A lot of times, I scan construction drawing to a raster image and then use the ALIGN command to get it on datum/scale. It’s not perfect but close enough for something like LOD stakeout. Quote
eldon Posted March 25, 2011 Posted March 25, 2011 Since you have made a block of the image, you can now insert that at a 1,1 scaling for the x and y axes. Now find the required scaling in the x and y directions by comparing the actual lengths with the given lengths. Now you can alter the x and y scaling in the properties dialogue box Quote
Seth385 Posted March 25, 2011 Author Posted March 25, 2011 Thank you for your suggestion. Unfortunately it hasn't solved my problem. I remember in AutoCad i had jpg with scale on it. Scale had values 0,5,10,15,20 m, so i drew a line between values 5 and 10, and entered scale 5 and picture streched so scale was representative in cad. I don't know how to do this in Civil3d. I'm not very familiar with Civil3d. I have tryed everything. Quote
eldon Posted March 25, 2011 Posted March 25, 2011 I thought that Civil 3D was AutoCAD with a few extra bits and pieces. So AutoCAD commands should work. Perhaps someone who uses Civil 3D will give you a few words of encouragement. Quote
eldon Posted March 25, 2011 Posted March 25, 2011 Perhaps your jpeg image is still a raster image rather than a block, but you did state that it was a block. Quote
Seth385 Posted March 25, 2011 Author Posted March 25, 2011 It's block. I know it's a bit simple problem. I'll keep trying. Quote
CyberAngel Posted March 25, 2011 Posted March 25, 2011 If you know the horizontal/vertical ratio, your best bet may be to resize the jpeg with an image editor so that the ratio becomes 1 to 1. AutoCAD only scales images on both axes, that is, you can't scale X and Y differently. Quote
Seth385 Posted March 25, 2011 Author Posted March 25, 2011 Soved. Turned jpg to block. Then in properties scaled each axis separately. There is an option. Thank you. Quote
CyberAngel Posted March 25, 2011 Posted March 25, 2011 Soved. Turned jpg to block. Then in properties scaled each axis separately. You can do that?? Who knew Quote
