Can someone help me with a lisp file to project arc and circle objects to the view and replace them with ellipses?
Thank you very much Lee Mac,
you are as always a great help:lol:.
Here is an old project.lsp from the Autodesk Training Department. It was written in the 80's before Autodesk put it's license from hell in the headers of any tidbit of code they included with the software. it's a good learning / teaching tool. -David
PROJECT.LSP
Perhaps this is suitable:
(defun LM:ProjectArc ( e / el l r n )
 (if (member (cdr (assoc 0 (setq el (entget e)))) '("ARC" "CIRCLE"))
   (entmakex
     (append
       (list
         (cons 0 "ELLIPSE")
         (cons 100 "AcDbEntity")
         (cons 100 "AcDbEllipse")
       (foreach x '(6 8 39 48 62 210)
         (if (assoc x el) (setq l (cons (assoc x el) l)) l)
       (list
         (cons 10 (trans (cdr (assoc 10 el)) e 0))
         (cons 11
           (polar '(0. 0. 0.)
             (angle '(0. 0. 0.)
               (trans (getvar 'UCSXDIR) 0 (setq n (trans '(0. 0. 1.) 1 0 t)) t)
             (setq r (cdr (assoc 40 el)))
         (cons 40 (abs (/ (* r (apply '+ (mapcar '* '(0. 0. 1.) n))) r)))
         (cons 41 (cond ( (cdr (assoc 50 el)) ) ( 0.0 )))
         (cons 42 (cond ( (cdr (assoc 51 el)) ) ( (* 2. pi) )))
(defun c:test ( / e )
 (if (setq e (car (entsel "\nSelect Arc or Circle: "))) (LM:ProjectArc e))
The code will project supplied Arcs/Circles drawn in WCS to the current UCS
David Bethel, thanks a lot.
Lee Mac, thank you again.
