SunnyTurtle Posted April 15, 2011 Share Posted April 15, 2011 Hi I am creating many new drawing which are exactly the same except they have a differing Xref. i want to create a drawing saved as 501.dwg to 703.dwg And I have xrefs that are called page x_page 1.dwg to x_page 202.dwg i have already created 501.dwg it has 1 block and 1 xref already in it. I want all dwgs to have this block and xref but have a another differing xref I’ve done stuff like this manually many times and I always thought there must be a way to automate it I have often made Scrips to help me out. But the saveas function is a part that need to vary I think lisp can do this but i an unsure where to even start. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 15, 2011 Share Posted April 15, 2011 saves should work in a script where you come undone is when it has spaces in the directory name or dwg name you could make it a variable in your script (setq newdnwgo "C:/dir1/job/his/dwgnamex") saves !newdwgno Quote Link to comment Share on other sites More sharing options...
SunnyTurtle Posted April 15, 2011 Author Share Posted April 15, 2011 Sound like a good idea. Even if i don't get the exact file names that i need i can run lupas rename over it to get the exact filename This is what iv got it still need a loop and all the commands from the script. also im still looking into a removing " lisp. (defun a () (setq ofl "L:/30011010/CAD/DWG/03_RD_Roads/300011013-DRD-050") (setq cout 1) (setq cout (+ cout 1)) (setq nfn (list ofl cout)) need something here to remove " (command "saveas" nfn) ) ;then repeat Quote Link to comment Share on other sites More sharing options...
pBe Posted April 15, 2011 Share Posted April 15, 2011 (setq ofl "L:/30011010/CAD/DWG/03_RD_Roads/300011013-DRD-050") Question for you: This pattern: drawing 501.dwg with xref page x_page 1.dwg ? drawing 502.dwg with xref page x_page 2.dwg ? Are the xref files (page x_page 1.dwg to x_page 202.dwg) existing? I would suggest using Wblock instead You can change the Xref Path before you wblock the entire drawing with a new name specified before invoking Wblock (vla-put-path CurXref [i]PathofNextXref[/i]) PathofNextXref= (strcat XrefPath "page x_page" (itoa cnt) ".dwg ") then (vl-cmdf "-wblock" NewName "*") (setq ofl "L:\\30011010\\CAD\\DWG\\03_RD_Roads\\300011013-DRD-050\\") NewNAme=(strcat ofl "Drawing_50" (itoa cnt)) in theory it shoudl work Quote Link to comment Share on other sites More sharing options...
SunnyTurtle Posted April 15, 2011 Author Share Posted April 15, 2011 Question for you: This pattern: drawing 501.dwg with xref page x_page 1.dwg ? drawing 502.dwg with xref page x_page 2.dwg ? Are the xref files (page x_page 1.dwg to x_page 202.dwg) existing? To answer your question the xrefs already exist. I am not sure about Xblock because I the xref need to be listed in the title block and someone else does that part. But thanks for your advise i will look into over the weekend Maybe or ill just play xbox ha ha Quote Link to comment Share on other sites More sharing options...
pBe Posted April 15, 2011 Share Posted April 15, 2011 To answer your question the xrefs already exist. Now that makes it easier Wblock (not Xblock btw) with "*" will make an exact copy of your drawing (including viewports and layouts and XREFS) Modfying the titleblock is to include the attached xref would be easy. (especially if you're using fields) Anyhoo... Maybe or ill just play xbox ha ha me too... Quote Link to comment Share on other sites More sharing options...
SunnyTurtle Posted April 18, 2011 Author Share Posted April 18, 2011 Hi pBe thanks for all the help i have now done this manualy and no longer have access to play around with the files seeing as i have move office. Is there any tutorals on how to use Wblock becasue i would like you learn more. Also are you able to overlay wblocks as xrefs. Quote Link to comment Share on other sites More sharing options...
