A co-worker of mine just got a new laptop. He installed Autocad 2010 on it. The issue he has is the any time he draws a line in model space. The line has thickness to it in the z-axis. It looks like a surface, but the properties show it being a line. Is there a default variable or something to change the line thickness to zero? Thanks.
What is the line thickness in properties?
Is it a line or pline?
What is the Visual Style? Make sure it is 2D wireframe.
THICKNESS is the variable.
"THICKNESS" did the trick. It was set to 100 for whatever reason. I now set it to zero.
