AutoCAD 2010 batch plot to PDF
Epicurwin
Do you have access to the mapped drive or is it disconnected? Try publishing to the Desktop and see if it works then.
I'm sure that the drive is connected, but I still tried publishing it to the desktop and I also copied the cad file to the desktop and publishing to the desktop. Same error, same issue.
Can you do a normal plot to pdf rather than publish. Maybe also download cutepdf its free, maybe something wrong with dwg to pdf ?
