Jest Posted May 6, 2011 Share Posted May 6, 2011 The first time I started Acad Map 3D 2012, I choose "2D drafting Workspace". Then I made some changages and saved It with different name. (e.g. "My Work"). I set it as current. But every time I close and reopen Acad, workspace is automatic switched back to "2D drafting Workspace", even if I set "My Work" as default and current in Customize user interface... I never met this problem before in previous versions. Can anybody help me to solve this bug? Jest Quote Link to comment Share on other sites More sharing options...
SLW210 Posted May 6, 2011 Share Posted May 6, 2011 _WSSETTINGS select "Automatically save workspace changes" under When switching Workspaces You may need to set up a template file, I do not use 2012 so this may be a bug. Quote Link to comment Share on other sites More sharing options...
Jest Posted May 6, 2011 Author Share Posted May 6, 2011 I thnik I've found the solution. I simly renamed "2d drafting Workspace" (added few characters in the begining..) It's working now..... so far. I hope it wont cause any other troubles in the future.. Quote Link to comment Share on other sites More sharing options...
