ReMark Posted February 19, 2013 Share Posted February 19, 2013 Yes, I agree, we learn best by doing. Practice, practice and practice some more. It just makes us better. Quote Link to comment Share on other sites More sharing options...
solo8591 Posted February 20, 2013 Share Posted February 20, 2013 Hey remark I see in the instruction it said to put the building dimention . is that includes the inside partition walls and all other the given dimention in the insid too in plate A or we just put the dimention for overall dimention around it only. Quote Link to comment Share on other sites More sharing options...
solo8591 Posted February 20, 2013 Share Posted February 20, 2013 dimension question Quote Link to comment Share on other sites More sharing options...
solo8591 Posted February 20, 2013 Share Posted February 20, 2013 is ther any key to press in the autocad to masure all the dimension one time by high light the area Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 20, 2013 Share Posted February 20, 2013 No there is not. If you wanted to know the lengths of all the lines in your drawing you would either have to use the LIST command and select all the lines or use a custom lisp routine. Why do you ask? Wait a minute... Are you asking if you can dimension an entire drawing with a press of a single key? If so the answer would still be "no" but there is a Quick Dimension feature in AutoCAD that might help. Be careful when using it though as the results can be unpredictable at times depending on how you pick the objects you want to dimension. Quote Link to comment Share on other sites More sharing options...
solo8591 Posted February 20, 2013 Share Posted February 20, 2013 The reason i asked is ,I useed the softwar called home designers and u build some kind of frame work with out any measurment, after u finished placing the frame work and all partition wall then just u hit the auto dimension button and that will put all the measurment in place . so that why i asked if we can do the same thing/ OR AUTOCAD HAS SOME KIND OF WAY DOING THIS once we build the frame work . Thanks Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 21, 2013 Share Posted February 21, 2013 There is no feature like that in AutoCAD. Quote Link to comment Share on other sites More sharing options...
solo8591 Posted February 21, 2013 Share Posted February 21, 2013 ok thanks i was just curious about the application. so which one is the fastest way to put the dimension fast except by turning the osnap and go from there by picking the qwick dimension command . Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 21, 2013 Share Posted February 21, 2013 The fastest way would be to use the Quick Dimension feature. Just be careful where and how you pick on your geometry. The use of OSnaps when making picks is highly recommended when it comes to accuracy. Quote Link to comment Share on other sites More sharing options...
solo8591 Posted April 7, 2013 Share Posted April 7, 2013 hello all ,Remark. please is any one has the HVAC plate#2 labeling on the numbers , i did the drawing but got confusing how to label them . i see some pdf picture put it is very hard to see how the numbers labeled please help in this one Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 7, 2013 Share Posted April 7, 2013 I probably have it on my work computer. Will look first thing Monday morning. Quote Link to comment Share on other sites More sharing options...
solo8591 Posted April 8, 2013 Share Posted April 8, 2013 Thanks I will look forward to that. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 8, 2013 Share Posted April 8, 2013 Is this what you are referring to? Quote Link to comment Share on other sites More sharing options...
solo8591 Posted April 8, 2013 Share Posted April 8, 2013 Thanks Remark that is great !!,it help to see how the # go ,thanks again. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 8, 2013 Share Posted April 8, 2013 I can post the remaining three developments Tuesday morning if need be. Quote Link to comment Share on other sites More sharing options...
solo8591 Posted April 9, 2013 Share Posted April 9, 2013 Thanks Remark that will be great Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 9, 2013 Share Posted April 9, 2013 There you go. Quote Link to comment Share on other sites More sharing options...
solo8591 Posted April 9, 2013 Share Posted April 9, 2013 That is awesome thanks very much . Quote Link to comment Share on other sites More sharing options...
coreyjaywilliams Posted August 1, 2013 Share Posted August 1, 2013 I am on plate three, does anyone have a list that clearly defines the true length measurments, im stuck!! (a-10, b-10 etc...) Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 1, 2013 Share Posted August 1, 2013 Unless the dimensions are included in the instructions PDF there is no list of true dimensions that I am aware of. Unfortunately I do not have access to a PDF for this segment of the P-F AutoCAD course. Did you look at post #6? Quote Link to comment Share on other sites More sharing options...
