Leyla Posted May 17, 2011 Share Posted May 17, 2011 I have saved a .dwg file that I'm using on my AutoCAD 2011 as an earlier version of AutoCAD (2007) and sent it to a friend who has 2009 version. She is getting an error message saying that the drawing is invalid. We tried using the .bak file and recovering the file and even inserting it in an open dwg. none of which works. I even sent her a .dxf file but it still doesn't work. I thought maybe it's because everytime I save a file AutoCAD generates a .dwxf file along with the dwg. so I sent her that file too but she still can't open the file. Any idea what it might be ?!! Quote Link to comment Share on other sites More sharing options...
BlackBox Posted May 17, 2011 Share Posted May 17, 2011 Instead of doing a SaveAs, I *believe* you need to ExportToAutoCAD. I don't have vanilla AutoCAD, but in Civil 3D / Land Desktop it's the _AecExportToAutocad20XX command, where 20XX is the file version. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted May 17, 2011 Share Posted May 17, 2011 Instead of doing a SaveAs, I *believe* you need to ExportToAutoCAD. I don't have vanilla AutoCAD, but in Civil 3D / Land Desktop it's the _AecExportToAutocad20XX command, where 20XX is the file version. Not in plain vanilla AutoCAD. Can you open the file that you are sending? How are the files being sent? Can you send the files saved in 2010 and have them use DWG TrueView to open and save down. Try saving to 2004 or 2000. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted May 17, 2011 Share Posted May 17, 2011 Not in plain vanilla AutoCAD. Thanks for clarifying, bud. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted May 17, 2011 Share Posted May 17, 2011 Instead of doing a SaveAs, I *believe* you need to ExportToAutoCAD. I don't have vanilla AutoCAD, but in Civil 3D / Land Desktop it's the _AecExportToAutocad20XX command, where 20XX is the file version. I stand corrected, it is command line only -EXPORTTOAUTOCAD or AECTOACAD notice the - in front of EXPORTTOAUTOCAD Quote Link to comment Share on other sites More sharing options...
Leyla Posted May 17, 2011 Author Share Posted May 17, 2011 Yes. I can open the file on my own computer. no problem there. and I sent the file over email first and then tried copying it on a USB and sent the file again that way . I'm going to try this export command and also try saving to maybe 2004 or earlier. Will get back to you with the results soon ! Quote Link to comment Share on other sites More sharing options...
KJB Posted May 17, 2011 Share Posted May 17, 2011 From Civil 3D 2010: _AecExportToAutoCAD2004 Note: Drawing will look like crap. Blocks will be larger and anonymous blocks. Quote Link to comment Share on other sites More sharing options...
Leyla Posted May 17, 2011 Author Share Posted May 17, 2011 Thank you ! Thank you ! Both of your tips worked perfectly. I used "save as" to autoCAD 2000 verison and she could open it. I also tried exporting, the "EXPORTTOAUTOCAD" command didn't work but AECTOACAD did and she could open both files. Thanks again Quote Link to comment Share on other sites More sharing options...
omargarciave Posted May 17, 2011 Share Posted May 17, 2011 For a best convertion, use Autodesk DWG TrueView, is much better convert files to others version of ACAD. And DWG TrueView is free. Quote Link to comment Share on other sites More sharing options...
shreenn Posted June 10, 2011 Share Posted June 10, 2011 Even I have the similar kind issue, but I have openned file in the latest version i.e. AutoCAD 2011 but still I'm getting same problem. If the file is corrupted it will give us the msg file corrupted but the msg I got is " Drawing file is not valid ". What would be the problem, anyone can plz help me out how figure this issue Thanks in advance Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 10, 2011 Share Posted June 10, 2011 Where did you get the file? Can DWGTrueView open it? Can you post the file? Quote Link to comment Share on other sites More sharing options...
shreenn Posted June 10, 2011 Share Posted June 10, 2011 yes I tried It, but it did not open in DWG true view, I got the same msg "file not valid". At the moment I can't share the file coz its in my office PC probably I can share it on monday. anyway thanks for the reply Quote Link to comment Share on other sites More sharing options...
landman620 Posted September 21, 2013 Share Posted September 21, 2013 I have the same problem with a file "drawing file is invalid" If I can't open the drawing how am I to Export to or save as an earlier version????? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted September 21, 2013 Share Posted September 21, 2013 DWGTrueView is free from Autodesk and will convert to a version you can open with 2007. This message also could indicate a corrupt file, try Audit the file, if doesn't open in DWGTrueView. Quote Link to comment Share on other sites More sharing options...
