Ellie82 Posted June 2, 2011 Share Posted June 2, 2011 Hi all, has anyone devised a routine where you can copy a block and it will number them each in sequence? If you imagine a reference for a piece of equipment, say in a circle, or square with a line across the middle, in the top there is text that remains the same, in the bottom half there is a number and as you add more references the numbers go up in order, so for 10 items you will have 10 refernces, each copied and then the text altered. Any ideas? thanks Quote Link to comment Share on other sites More sharing options...
VVA Posted June 2, 2011 Share Posted June 2, 2011 Increment value Lisp needed (with frames) Look Binc or BincA command Quote Link to comment Share on other sites More sharing options...
