Importing prj sdi sdc files into AutoCad 2012???
A client has sent me some files prj sdi sdc, which are part of a shape file i guess. Does anyone know how to import the data into AutoCAD 2012???
Am totally stuck. I know how to import normal shapefiles (shp shx dbf).
Edited by martyn gray
As long as you have the shp,shx and dbf files thats all that you need. The prj file is the projection file (coordinate system) and is read when you import the shape file. The sdi, sdc, etc are read by E$RI applications only and not used with AutoCAD.
