Delay in copying
ceeyespee
 Share
While working on 2D drawing (not all the drawings), when I copy a part of the drawing, the system seems to hang for more than a minute and get restored in steps. I had tried -scalelistedit solution and to no effect. Can somebody help?
(not all the drawings) may be the key here: outside files from other vendors? or other versions of AutoCAD (Like Civil or Architecture)?
Try doing a -Purge RegApps as well. Also Audit the dwg. If there's still weird stuff happening, perhaps there's some vertical used to generate the drawing to begin with, see if you have the ObjectEnablers installed. Also try my DictEdit routine (post #7) to see what other dictionaries are still left in the drawing.
 Share
