fisher22
finding distance between offset lines
fisher22
Hi,
Im completly new to CAD so this is probably going to sound stupid but how would I find the distance between two offset lines. Basicaly what I have got is straight line with an original offset line at the base and I have copied this line at different distances along the line, but I need a way to double check the distances from the original line. Again sorry if it is really simple.
thanks alot,
Steve
Share this post
Link to post
nestly
You have several options including:
Distance command (DIST) and pick any two points
MeasureGeometry command (MEASUREGEOM) from the Ribbon or the Command line, and pick any two points
Create a dimension between any two points.
Share this post
Link to post
eldon
Using Osnaps, the first pick point will be at the End, Middle or Near the line, and then for the second pickpoint, you must use Perpendicular to the second line.
Share this post
Link to post
BlackBox
This may help:
(command "._dist" "near" pause "perp")
Share this post
Link to post
fisher22
Thanks alot sorted
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
