Getting error while running Visual lisp program in ACAD2007.
drawings
Trying to run any visual lisp code in AutoCAD 2007, but end up in getting an error.
; error: ActiveX Server returned an error: Error loading type library/DLL
Is it a virus which is causing problem ? Becuase on other PC with same AutoCAD 2007 I don't get above error.
Without seeing the code you're attempting to run, the error message above does not provide me enough information to know exactly what is the cause.
Try running (vl-load-com) at the command line, to load the Visual LISP extensions, and try your code again. If this fixes the problem, then be sure to add (vl-load-com) to either your routine (at the top), or to ACAD.lsp / ACADDOC.lsp so you only need it once.
If (vl-load-com) does not solve the issue then you are tapping into another external object's interface, and the specified file path for said type library (i.e., Excel.exe) cannot be found... in order to correct something like this, the file path must be corrected.
Hope this helps!
Thanx Renderman,
Here is the code which I am trying to run.
;;Program to get Mass Propertise of the objects....
(defun C:mass_p ()
(vl-load-com)
(while
(setq sset (ssget))
(setq ctr 0)
(repeat (sslength sset)
(setq item (ssname sset ctr))
(setq item (vlax-ename->vla-object item))
(setq vol (vla-get-volume item))
(princ (strcat "\nVolume: " (rtos vol)))
(setq ctr (1+ ctr))
);repeat
);while
);defun
As I select object & hit Enter, I receive error :
I trying to figure out the problem from last 3 days. I need help.
:ouch::ouch::ouch::ouch:
Edited by SLW210
CODE TAGS!!!!!!!!!!
Consider this example instead:
(defun c:MASS_P  (/ ss)
 (vl-load-com)
 (while (setq ss (ssget "_:L:S:E" '((0 . "3DSOLID"))))
   (prompt
     (strcat
       "\n  >>  Volume: "
       (rtos (vla-get-volume (vlax-ename->vla-object (ssname ss 0)))))))
 (prompt "\n** Command ended, or non-3DSOLID selected ** ")
 (princ))
This code will continuously allow a single, non-locked, entity selection of "3DSOLID" objects (the only objects which possess a volume property).
Another way . :)
(defun c:Test (/ lst ss i sset lst)
 (setq lst 0)
 (if (setq ss (ssget "_:L" '((0 . "3DSOLID"))))
     (repeat
       (setq i (sslength ss))
        (setq sset (ssname ss (setq i (1- i))))
        (setq
          lst (+ (vla-get-volume (vlax-ename->vla-object sset)) lst)
     (alert (strcat " The Total Volumeis : " " " (rtos lst 2)))
Tharwat
... And another one:
(defun c:TEST2 ( / ss v tot)
 (vl-load-com)
     (textpage)
     (vlax-for x (setq ss (vla-get-activeselectionset
                            (vla-get-activedocument
                              (vlax-get-acad-object))))
       (prompt (strcat "\nVolume: " (rtos (setq v (vla-get-volume x)))))
       (cond (tot (setq tot (+ tot v))) ((setq tot v))))
     (prompt (strcat "\n  >>  Total  >>  " (rtos tot)))
     (vla-delete ss))
   (prompt "\n** Nothing selected ** "))
 (princ))
(defun c:TEST3 ( / ss)
 (vl-load-com)
   ((lambda (i / e v tot)
      (textpage)
      (while (setq e (ssname ss (setq i (1+ i))))
        (prompt
          (strcat
            "\nVolume: "
            (rtos (setq v (vla-get-volume (vlax-ename->vla-object e))))))
      (prompt (strcat "\n  >>  Total  >>  " (rtos tot))))
     -1)
 (princ))
Dear Renderman,
I must appreciate your work. I have checked it & have a run on different PC (not the one having problem). Every program worked fine. I will check it on the problem PC & will post a feed back. Thanks once again.
