Bevel Gear Support in 3D AutoCAD
Bobzy20
I'm drawing this item in 3D AutoCAD and I wanted to see if I'm drawing it right.
All the fillets seem to clash with each other and I'm thinking I might have drawn it wrong?
Does anybody fancy drawing it and letting me know?
For a larger version of the Bevel Gear Support drawing see the link below:
http://iadesigns.com.au/53_Bevel_Gear_Support_exercise.jpg
Looks like you might have drawn some portion of the part incorrectly that you ended up with the result shown above. Did you go back and check?
I had the above measument at 25 but after chnaging it to 12.5 the 25mm fillet seems to fit ok and now meets the edge.
