Trovato14 Posted August 9, 2011 Share Posted August 9, 2011 I am using the monochrome plot style and plotting to PDF. My text looks great in the Plot Preview, but once actually hit 'Plot' the line weight of my text and dimensions appears super thick and heavy. They are also assigned to the lightest line weight in the layer property manager. Any suggestions would be so helpful! Thanks so much. Quote Link to comment Share on other sites More sharing options...
Ahankhah Posted August 9, 2011 Share Posted August 9, 2011 (edited) Check these areas and instructions: 1- Issue LWEIGT command, then check the default lineweight and if necessary decrease its value to lower one. 2- When you are in Plot dialog, enable the Scale lineweights check box in Plot scale region. Edit: I didn't mention your post correctly, so please do not take attention to my impertient answer. Edited August 9, 2011 by Ahankhah Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 9, 2011 Share Posted August 9, 2011 Is it possible that the "Z" of your text is something other than "0"? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 9, 2011 Share Posted August 9, 2011 What are you using to plot to PDF? Have you tried a different font? Quote Link to comment Share on other sites More sharing options...
rkent Posted August 9, 2011 Share Posted August 9, 2011 You don't mention the font you are using, TTF ignores the lineweight settings, SHX will work as you are expecting. Quote Link to comment Share on other sites More sharing options...
Trovato14 Posted August 9, 2011 Author Share Posted August 9, 2011 Wow, thanks everyone for your quick replies. I am plotting to PDF. I was indeed using a TFF Font, but tested the ARIAL font provided in the program on the word "ISLAND." I set the default in LWEIGHT to .05mm and also checked box 'scale lineweight' in the plot dialog. Still no change to the font when I plot. All looks nice and thin in plot preview, but final result is very heavy. What does "Z" mean? BT-Moffett Kitchen FINAL PLAN.pdf Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 9, 2011 Share Posted August 9, 2011 "Z" refers to elevation. Maybe your text is sitting above the X/Y plane at a height other than "0". It's been known to happen. Quote Link to comment Share on other sites More sharing options...
acadesign09 Posted August 9, 2011 Share Posted August 9, 2011 I am using the monochrome plot style and plotting to PDF. My text looks great in the Plot Preview, but once actually hit 'Plot' the line weight of my text and dimensions appears super thick and heavy. They are also assigned to the lightest line weight in the layer property manager. Any suggestions would be so helpful! Thanks so much. Maybe ur setting in your plotter has mark CHECK the line weight...all u have to do just uncheck the in ur plotter. Quote Link to comment Share on other sites More sharing options...
rkent Posted August 9, 2011 Share Posted August 9, 2011 Wow, thanks everyone for your quick replies. I am plotting to PDF. I was indeed using a TFF Font, but tested the ARIAL font provided in the program on the word "ISLAND." I set the default in LWEIGHT to .05mm and also checked box 'scale lineweight' in the plot dialog. Still no change to the font when I plot. All looks nice and thin in plot preview, but final result is very heavy. What does "Z" mean? AutoCAD ignores lineweight for TTF, you can change lineweights all year long and AutoCAD will still ignore that for True Type Fonts. (See help if you don't believe it.) Select all text in the drawing, open properties, in the Z elevation swipe over what ever is listed, even if it says zero, and type in 0. See if that helps. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 9, 2011 Share Posted August 9, 2011 What are you using to plot to PDF? If you are using DWGtoPDF.pc3, maybe you should try CutePDF. Did you try using a SHX font to see if the problem goes away? Quote Link to comment Share on other sites More sharing options...
