liv-k Posted September 11, 2011 Share Posted September 11, 2011 Hello, I'm having a weird problem. When I hit render button nothing happens. I've reset the setting, I have even renamed the 3dsmax.ini file but it doesn't work. I would really appreciate it if someone could help me. Thank you in advance liv-k Quote Link to comment Share on other sites More sharing options...
Cad64 Posted September 11, 2011 Share Posted September 11, 2011 Have you tried closing Max and restarting? You might also try opening a new file and then Merge your scene into the new file. Quote Link to comment Share on other sites More sharing options...
liv-k Posted September 11, 2011 Author Share Posted September 11, 2011 I've restarted max and my computer also. I checked various files to see if it works but it does the same thing with all of them. So I don't think it's a fault of the specific file. If nothing happens I'm thinking to reinstall the program. I believe that something crashed. Thank you for your answer though Quote Link to comment Share on other sites More sharing options...
Cad64 Posted September 11, 2011 Share Posted September 11, 2011 If it happens in all files then try running a repair. If the repair doesn't work then you will probably have to reinstall. Quote Link to comment Share on other sites More sharing options...
liv-k Posted September 11, 2011 Author Share Posted September 11, 2011 I reinstalled it cause repair didn't work eventually. Everything works just fine now! Thank you very much for your quick response! Quote Link to comment Share on other sites More sharing options...
