CelticMac Posted September 12, 2011 Share Posted September 12, 2011 I have existing drawings that I copy and manipulate into new ones. I have a drawing of a conveyor line that has some segments "highlighted" with a yellow hatch that appears to follow a single line. The conveyor layout has been changed. So I need to update the drawing for the new layout. I'm wondering how this was drawn. I cannot explode the hatch to copy parts of it. I'm thinking there was probably a simple way to get the hatch to follow the drawn line. Putting boundaries around the drawn line to hatch in would be rather time consuming. Is there a simple function I don't know about? Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 12, 2011 Share Posted September 12, 2011 Is it a hatch pattern or a block? Quote Link to comment Share on other sites More sharing options...
nestly Posted September 12, 2011 Share Posted September 12, 2011 Maybe this method would work? Make the line into a polyline, copy it on top of itself, give the original polyline a a global width (the original will be drawn "below" the copy) , and make it yellow Quote Link to comment Share on other sites More sharing options...
SLW210 Posted September 12, 2011 Share Posted September 12, 2011 You will need to post the file or select the entity in question and then use properties to see its description. Quote Link to comment Share on other sites More sharing options...
CelticMac Posted September 12, 2011 Author Share Posted September 12, 2011 Here's the file. 305CONV.dwg Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 12, 2011 Share Posted September 12, 2011 (edited) Well I was able to explode the rectangular one and separate the hatching from the boundary. Haven't been able to do that on a couple of the other ones though. And he did use a SOLID hatch as it is right there in the Hatch command as one of the choices. Edited September 12, 2011 by ReMark Quote Link to comment Share on other sites More sharing options...
CelticMac Posted September 12, 2011 Author Share Posted September 12, 2011 Thank you, nestly, that worked well. Quote Link to comment Share on other sites More sharing options...
