CaveMan Posted September 13, 2011 Share Posted September 13, 2011 Good Day Have a drawing with multiple xref's , Blocks within it. Drawing geometry is a combination of 2D and 3D. Would like to project this onto a 2D plane - "FlatShot?" and then save it as another drawing. Main reason for this is for a KeyPlan - routing diagram for a plant If anyone knows of a quck method would greatly appreciate Software been used AutoCAD 2010 & 11 Regards CaveMan Quote Link to comment Share on other sites More sharing options...
rkent Posted September 13, 2011 Share Posted September 13, 2011 You could probably use Flatten or SuperFlatten (search on internet for SuperFlatten) on a copy of the drawing. Flatten is an Express Tools command. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted September 13, 2011 Share Posted September 13, 2011 The FLATSHOT command works only with Solids, not Meshes. I would highly recommend FLATSHOT as the results are extremely accurate. It will make anything 2D in the drawing, including XREF's. Quote Link to comment Share on other sites More sharing options...
