blackeagle1245 Posted September 14, 2011 Share Posted September 14, 2011 I have blocks in my drawing that has name *u207. But I cant just Insert these block or change it. How does "*" command works? Quote Link to comment Share on other sites More sharing options...
dbroada Posted September 14, 2011 Share Posted September 14, 2011 assuming MEP works the same as AutoCAD they are anonymous blocks. They are very difficult to control although there are a number of LISP routines in this forum that will make them accessible. Search for anonymous blocks or check the similar threads below. Quote Link to comment Share on other sites More sharing options...
blackeagle1245 Posted September 14, 2011 Author Share Posted September 14, 2011 ok thanks. And I need lisp to control them right?. Is there anyway to see at least the folder that it comes from?. I'll search for anonymous blocks. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted September 14, 2011 Share Posted September 14, 2011 (edited) I believe *u can be created from dynamic blocks, you may want to search for that as well as anonymous blocks. Corrected, my mind and fingers do not seem connected properly today. Edited September 14, 2011 by SLW210 Brain lock-up Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 14, 2011 Share Posted September 14, 2011 *U is a uniformly scaled anonymous block. *E is a non-uniformly scaled anonymous block. The first can be exploded using the EXPLODE command. Convert an anonymous block with a *U prefix to normal AutoCAD block by using a lisp routine called UNANON.lsp found here... http://www.draftsperson.net/index.php?title=Anonymous_Blocks_in_AutoCAD Quote Link to comment Share on other sites More sharing options...
