Accessing objects without going to each layout tabs one by one, it is the problem.
Ahankhah
Hi friends,
how is it possible to explode all blocks in all spaces (layouts) without setting each tab current (I mean issuing (setvar 'Ctab ...))
Thanks in advance
My approach also .... it works perfect .. :D
With ssget "_x" you can select all objects in model and in all layouts as well .....
(defun c:TesT (/ ss i) (vl-load-com)
;;;=== Tharwat 24. Sep. 2011 ===;;;
 (if (setq ss (ssget "_x" '((0 . "INSERT"))))
   (repeat
     (setq i (sslength ss))
      (vla-explode  (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
Tharwat
You're welcome Mehrdad . :)
I am so happy to be of assistance with experienced guy like you .
Regards.
I study many things in CADTutor from you and other CADMasters :thumbsup:
