DWG forces to Partial Open always
I'm trying to run my cleanup script on a set of drawings just received from a consultant. Unfortunately every time a DWG is opened the purge fails with:
PURGE cannot be used on partially opened drawings.
Now to get the file opened NON-partially, I have to first open as partial and click the "Load All" button and "Yes" to bloodywell open it normally. Then the purge actually "works".
This needs to be done manually. Yet even after I've done this and then saved the DWG again, another normal open again gives the same error about Purge not allowed.
Anyone have a clue how to get the DWG to open non-partially when I'm running my SCR? I don't want to clean the 80+ drawings manually.
