Need help to run macro
Hi, I need help to run macro whith button, the macro name is CARCH.DVB the macro was in the folder c:autocad2007\macro\carch.dvb. The macro a userfrom and in module1 I have a sub whit say show userform1. The macro was load in autocad and I try to use command -vbarun but i does'nt work autocad say macro not found.
Thanks
Did you load macro into Autocad?
Open VBA and check if macro is present. Try to run macro from inside VBA.
Yes it'S load.
But when i try to run I can i don't see it. to run my userfom I have to go in vb editor and push the run buttton. I just work in one drawing.
Looks like you need to add it to startup suite, and make sure it is in search path of Autocad.
And if you use it frequently make button to run it.
Maybe this will help
(defun C:toolkit ()
(vl-vbaload "S:/AutoDESK/VBA/Design Toolkit.dvb")
(vl-vbarun "ToolKit")
