Hyperbolic paraboloid mesh problem
gooooog
Hi i've got to grips quite well with mesh modelling but i cannot seem to be able to mitigate this shape, a hyperbolic paraboloid in 3D Cad (see attached image)... can anyone give me any guidance on this matter?
Thanks
Clive
convert what into a surface? ive tried loads of different ways theres no guidance tips on youtube or the internet.
thanks
Clive
im using it for a restaurant im designing for my uni project. how do I get hold of a path or can i import that picture somehow?
thanks
...how do I get hold of a path
3dpolyline
You could import your picture, but I don't know what good that would do.
Attach here what you have completed so far if you can't figure it out.
You are doing too much work - you only need the 4 boundary edges.
Create using 3Dpoly with C (for close) as your last point.
or
you could use Loft with Guide curves, but I think I would simply use a closed 3dpoly and Patch.
right click and select proper option that will allow you to select the 3Dpoly boundary)
this really isnt working... i must be doing something wrong
Do the cube wire frame.
start 3dpoly and click the boundary points (use C for close on last point)
Do a Patch (check right mouse button options for proper selection).
For something like this I’d recommend using the Loft methodology – though I think 2 lines is enough (see attached).
Patch is useful; though in this instance the resultant geometry is a trimmed surface. AutoCAD does not treat it as such, but the isolines suggest it – the Acis/Brep information confirms it.
So, even if the surface is within tolerance, the Patch will not have traits associated with the doubly ruled hyperbolic paraboloid, nor a regular (fully contained) UV Parametrization.
LoftVsPatch.dwg
