neokeelo Posted June 16, 2006 Posted June 16, 2006 I have about 1000 AutoCad files that were messed up when converted from MicroCad to AutoCAD. I have the correct pdf versions of them though. So is there anyway I can convert the pdf files to fully editable files for AutoCAD (.dwg)? I need something that will keep the text and layers from the pdf file. If I can do this it will save me weeks of work. Thank you for any help you can give me. Quote
FazBear Posted June 18, 2006 Posted June 18, 2006 i don't think its possible, if anyone knows a way i would find it very useful. Quote
Gravesent Posted June 18, 2006 Posted June 18, 2006 Perhaps this works, I never tryed it thou. http://www.freedownloadscenter.com/Multimedia_and_Graphics/Graphics_Viewers/PDFIn_PDF_to_DWG_Converter.html Quote
fuccaro Posted June 19, 2006 Posted June 19, 2006 Open the PDF in COREL DRAW and save in DXF or DWG format. Also Illustrator will do the work. Quote
Barry Posted June 25, 2006 Posted June 25, 2006 There is a brilliant little piece of software called: Aide PDF to DXF converter It is available to down load to trial from http://www.aidecad.com . I use it frequently and it saves hours of effort. Hope this helps Quote
macareewall Posted March 12, 2009 Posted March 12, 2009 Take a look at this thread: http://www.cadtutor.net/forum/showthread.php?t=15383&page=2 Quote
fuccaro Posted March 12, 2009 Posted March 12, 2009 Yes, Macareewall, that thread is about the same thing. Just that thread is newer; you just answered an almost 3 years old question! Quote
