Battman ....without moving positon of text?
Hy everybody,
I use a block more than 50times in a plan, now a need to udate my attribute (color of text) but i have moving those attributes in function of the position on plan.
Can i use battman to make a update of my blok/attribute...but i need that all attribute stay at the same position on plan?
Many thanks,
Bono.
Hi pmxcad,
I don't no this solution but the customer don't want dynamic block!
So i'm searching for another option if it's possible?
So after Battman that the attribute can stay at the same place on plan.
Thanks!
There is nothing wrong with using dynamicblocks. You only have to make the attributes dynamic. The only problem is when you use something like exellink, does not work with dynamic blocks. Iam using autocad electrical......super. can export to excel and imports it again and works with dynamic blocks. If you want me to help you creating dynamic blocs.......let me know.
Pmxcad
