ali888 Posted October 18, 2011 Posted October 18, 2011 Hi, Just wondering if anyone might be able to help me with joining lines into polylines in autocad 2007. Basically, I got stuck when joining several lines together using PEDIT and then Join. At the start, it was very smooth process with no drama. Then, I came across two polylines and wanted to join them together, it just did not work. It works most of the time. Would anyone be able to tell me why I can't join certain lines together or two polylines together. This is a 2D drawing CAD. Thank you very much Quote
SuperCAD Posted October 18, 2011 Posted October 18, 2011 What kind of shape is it? Sometimes it is easier to start with a closed polyline and chamfer/fillet corners to get your desired shape than it is to make a bunch of lines and expect AutoCAD to work like a $4,000 program should. Quote
Organic Posted October 18, 2011 Posted October 18, 2011 Do the lines have different z values (i.e. are on different planes)? Quote
eldon Posted October 18, 2011 Posted October 18, 2011 If the ends of the two polylines are not at the same precise point, they will not join. Try using Fillet (with R=0) in this case Quote
